Results 1 to 3 of 3
Thread: Ute Rear Window Glass Measurements
    St Helena,Melbourne
    4.28 MB
    If anyone has a jap dual cab ute can you please post up the measurements of the rear screen including the seal, i need height as well as the width across the top and bottom of the screen. I want to see if i can use the glass from a factory vehicle as the rear screen for my rangie ute. I have seen those oval caravan windows use but they look dicky to me and custom cut toughened glass will be $$$ - i used perspex in a cut down top tailgate frame but perspex is a no go for it to be engineered so i'm told. Once passed i will remove it and use the hinged perspex window.
    thanks,
    Nick.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Singapore via Melbourne
    not quite what you asked for, however I remember reading/hearing years back about the use of an early suzuki sierra windscreen (which is flat) in the same role... dunno if it helps, but worth a shot
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by EchiDna View Post
    Might have to measure one although i think it will be too wide, even a ute one may be too wide but i wont know till i get some dims.
    1974 VW Kombi bus
