For those of you that have winches on their D2, does the winch bolt to the winchbar or to the chassis behind the crush cans?
My bar is a TJM T15 winchbar which apparently needs a frame, available from TJM for $200 or so, to install the winch. Does anybody have any detail on the frame? I would prefer to make it myself.
Best regards
Phill
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
G'dy, I have a D2 with the TJM bar and winch fitted. If you want to take a look just pm me
D4 SDV6, a blank canvas
1974 VW Kombi bus
My alloy bar(D2) is marked as airbag compatible for a D2.No crush cans fitted.
Interesting that the winch is fitted seperately to the chassis,Ive not bothered looking into winches due to needing to change the bullbar as well.One could get a cradle,or make one and just cut the hole in the bar for the fairlead
Something else to spend $$$$ on
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
I modified my winch cradle to allow the winch to be dropped out the bottom without having to remove the bbar. I cut the bottom out of the cradle then welded tabs to it that bolt to the side and back of the rest of the cradle. I also bolted a tow hook to each side of the cradle - they point down slightly and poke out slightly below the bar.
Hmmmph! Previous owner fitted nice big ARB bar but did not get the winch bar, so haven't pursued this as would mean cost of winch plus new bar
Mike
'00 D2 Td5 'Alice'
'03 V6 Freelander 'Phoebe'
'04 Td4 Freelander 'Harry'
Visit ARB 2Rocks.It may well be the only difference in the ARB winch bar and the non in a D2 is the slot and the seperate cradle.
Has your D2 got the ARB recovery points????
If not I know of a set in WA that have been donated to AULRO for fundraising.These are D2 ARB bullbar specific recovery points,and only bolt onto such a beast.
Let me know if you are interested we can work out a price.
Andrew
