Results 1 to 9 of 9
Thread: 06 Defender Rear Diff
    Free Again Thanks Dan
    A mate has a 06 Defender Wagon , He wants to know if a diff centre out of a s1 disco will fit in the the rear of his defender
    Reason being he has a 24 spline locked disco centre and wants to know if it will fit the P38 type diff housing in his Defender
    Jan 2008
    Gladstone, Queensland
    If you know the make of the locking diff, go to the manufactures web site and look it up on their vehicle selction/application charts.
    Ray.
    Jun 2007
    Quote Originally Posted by rangieman View Post
    is it a 90 or 110 ?
    Its most likely to be a 110 Dave. no 90's out here past 03.
    Pete
    Quote Originally Posted by ashtrans View Post
    is it a 90 or 110 ?
    Sorry 110 , i thought the P38 type diff would have discribed it as a 110
    Christchurch NZ
    My diff saga continues..
    Looks like it
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Jun 2007
    your're right but I don't assume anything,
    you can fit the disco diff centre into the P38 diff with a 5mm spacer to get the right offset :
    Ashcroft Transmissions
    I gather that spacer goes in between the crown wheel and the carrier
    Jun 2007
    yes, to get the right crown wheel offset,
