Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Best way to cut a big lock???
    Jun 2007
    Oatley, NSW
    Ok... so I use a padlock on my spare tyre to keep anyone from stealing it. I was washing my car today and swapping my tyres, so I just swapped the spare over, locked it and left the key on the tray. I then stupidly got in and went for a drive to subway and when I got there I ended up finding that I lost the key!
    So anyway. What's the best way to cut this thing? I'm thinking an angle grinder with a cutting disc? yes?
    Stirling
    Melbourne, outer South East
    Bolt cutters ......the real big ones.
    Yass NSW
    Quote Originally Posted by waynep View Post
    and if that don't work wrap a 30meter chain around a couple of major trees and the tyre and take if like you stole the rig.
    Use bolt cutters and then if you have to resort to the mangle grinder
    a dremel with a diamond abrading wheel will work but dont let it get too hot or the disc will shatter.
    but they are hard to get so in no particular order.
    a Die grinder
    Big bolt cutters
    An Arc welder
    A mig welder
    A gas axe..
    jsut depends on how much room you have
    I think big bolt cutters are the way to go.
    When I was building my house several years ago, that is what was used by some b******d who cut the lock put on the gate by the Electricity Commission so that he could help himself to my Durden Junior Joiner and a few other tools.
    That Elec Comm padlock was pretty big and it did a pretty neat cut.
    In fact it always amused me that he chose to cut the hasp on the padlock when the chain links were only about 1/4 the size.
    Melb. Vic.
    I have seen a locksmith pick one in a few minutes. Not sure how much they would charge.
    If you're going the angle grinder, grind the body of the lock - usually brass - rather than the hardened steel hasp.
    Simon
    Jun 2007
    Oatley, NSW
    Ok... so who has some big bolt cutters around my area haha. I have access to a mig, So the idea with using the mig is to make the metal softer by heating it and letting it slowly cool? ANd then hit it with an angle grinder? Or just crank the mig up and try to blast through the metal?
    I can see my alloy rim getting punished here
    Stirling
    tonyt Guest
    try to freeze the lock with liquid nitrogen and snap it of
    Apr 2007
    Central Coast NSW
    Try your local Police station. Whenever someone leaves their gun key at home the Sgt gets out the 'big red key' to snip the padlock off. It's easier to bust the lock than go through all the crap to have a Duty Officer find the spare key and 'authorise' you to use it.... Should have left it like the old system - chuck the .38 in your locker, take it home, hide it under a desk....
    Give it a go, it'll probably be the only free option
