Results 1 to 4 of 4
Thread: Gilring Brake booster
    Quinnsta Guest
    Question Gilring Brake booster
    Good evening all,
    As is common knowledge the brake master cyliner between SWB and LWB is different, however does the same apply for the factory Girling brake booster?
    I am about to fit one to the behemoth (109") and it came originally from Gumby's 88" he stripped.
    Many thanks in advance
    The parts books for the 2a show the servo only for the six (which is 109 only).
    The optional equipment parts book shows the single circuit master cylinder the same for 88 and 109 but the dual circuit one as different for 88 and 109. Both of these are listed only for Series 3 although the book covers Series 2a and 3.
    The brake booster that you have, is this the remotely located, in-line unit, or the one mounted with the main master cylinder?
    Aaron.
    Quinnsta Guest
    Hi Aaron It is one that is complete with pedal box, single circuit.
