Thread: water generator.
    water generator.
    Ok it hasnt been raining here but its cold...
    SWmbo just sent me out to turn the lights off and close the garage door. I got a bit wet from the condensation that had formed on the door to the garage and insperation hit...
    what if I put a small fan over it to increase the air flow so the metal can condense more water.
    what if I made a kind of S bend duct where the cold side of the peltier cooler attached to a small heatsink in the bottom part of the ducting cools the air on it and drops the moisture out of it while the hot side is on a larger heatsink on the top of it so that the heat makes the top part of the S bend work like a chimney and draw more air through the duct.
    What IF it was all solar powered?
    I think I have some experimenting to do.
    Yinnar South, Vic
    Sounds like your takeing acid
    Tregeagle, NSW
    you have far too much time on your hands, must have to be able to have 'free thoughts'
    but alas you are a bit late someone else has thought about it.
    here
    Making Water From Thin Air
    and here
    Air2Water - pure water, water machine, water from air, residential water cooler, water system
    just google 'water from air'
    saw one at an Ag show last year, looks a bit like a stand alone cooler.
    john
    Brisbane, Inner East.
    Dave, have you been at the jar of rum again?
    URSUSMAJOR
    right ideas, different concept...
    the salt absorbsion one is about the least energy effecient but about the most effective.
