Results 1 to 10 of 18
Thread: Tracks4Australia
    Sydney, NSW
    Tracks4Australia
    Tracks4Australia
    May be a silly question and apologies if so, but do many people use these?
    I have used tracks4africa and assume its the same organisation. Thinking of getting / using when I come over in November...
    Is there a better alternative? We already have the Hema 4WD tracks CD and maps...
    Regards,
    Jon
    Hi Jon, try .:GPS Australia:. for information and other options
    I can't give too much advise on mapping software except to say most of it doesn't cover where I live to any great detail.
    Apr 2007
    UK
    Hi Yorkshire Jon (great name BTW, I'm Jon and I'm from Yorkshire originally!)
    I have both Tracks4Australia and ShonkyMaps installed on my carputer, you can freely switch between the different maps in MapSource.
    I find that ShonkyMaps has a little bit more detail than Tracks4 of the places I 4WD on over here in WA, however to be honest they are both based on government maps that are many years old (like 20) and in some instances from a 1972 survey! They have very little detail of the smaller tracks and it's impossible to distinguish between a right of way and a private track / road. For example a road is shown just near to where I live, and yet it is on private land with padlocked gates at each end of it.
    I'm still learning how to get hold of decent digital maps of WA, without resorting to scanning paper copies of the DLA & CALM (land management) maps and using OziExplorer which I don't particularly rate. I've found that Google Earth with the "roads" layer turned on is pretty useful for pre-trip planning as it shows loads of detail of the smaller tracks - Google maps gives the same results. Unfortunately this is of no use when you are in the car!
    I've noticed that the Magellen maps of Australia seem to use the same source as Google maps and has nearly all of the small tracks in it, being a tight Yorkshire git though I refuse to spend $1200 on a GPS just to get their maps! I've also found no way of converting their maps to run on anything other than their GPS / PC software (which I guess is fair enough)!
    Unless I'm missing something significant, it seems to me that decent (i.e. current and at least 1:25000 scale) ) digital maps of WA are virtually non-existent, I believe the mapping is better in some of the other States & Territories. WA is a very big place, so it is understandable - although I still find it pretty poor that the mapping provided by the government is still very poor even close to the major population areas (like Perth).
    Private companies (like Hema) have capitalised on the pi$$ poor official mapping of the country and produced accurate maps of popular routes like the Canning Stock Route, etc.
    Hope this helps, although I think it turned into a bit of a rant
    Jon
    EDIT...
    I went on a fresh search and wonder if OzTopo V2 is any good, <click here> I notice in their FAQ that they get their road & POI data from MapData Sciences Pty Ltd, who's name appears at the bottom of the viewing screen in Google Earth when looking at Australia. Does anyone have this product and is it any good (i.e. more detail of tracks than Shonky / Tracks4)??
    Cheers Jon
    Last edited by D3Jon; 29th May 2008 at 04:24 PM. Reason: Added stuff after EDIT...
    Perth, WA
    Quote Originally Posted by D3Jon View Post
    Cheers Jon
    I'm actually waiting until I can see that, as it looks promising but I don't want to find I have a $200 lemon that is no better than the free ones.
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Margate, TAS
    I think you might find this is a combination of 2 products - GPS TopoPlus which is 10m contour data for Australia and Tracks4Australia Pro which is the commercial version of Tracks4. So far I've found Tracks4Australia to be semi-useful - as it's based on GPS tracks submitted by users it's only as good as their data.
    Personally I still don't understand why more map products are not available digitally but that's probably the modern way - wait till someone produces it commercially, which in a relatively small market like Oz could be a while
    cheers, Andy
    PS another exiled Yorkshireman
    I looked at these maps when I first got my GPS but found Shonkymaps to be better.
    Shonkymaps by Shonkylogic
    ...and they're freeware
    Jun 2003
    Launceston, Tasmania
    I ise tracks4australia and shonkymaps depending on what i'm doing.
    If i'm road touring, I load on the shonkymaps, if I'm off roading, tracks4australia.
    I would like tracks4australiapro, but I'm not about to cough up for it. I also have a topo overlay to go with tracks4australia. it's available freely as well if you check out GPS australia
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Apr 2007
    UK
    Quote Originally Posted by jik22 View Post
    That's my feelings exactly.
    Quote Originally Posted by AndyRevill View Post
    I think you might find this is a combination of 2 products - GPS TopoPlus which is 10m contour data for Australia and Tracks4Australia Pro which is the commercial version of Tracks4. <snip>
    I wondered if V2 of oztopo had moved a way from the Tracks4Australia Pro data, and was now much more detailed because it used the roads & tracks data from MapData Sciences (the guys who supply Google Earth with their almost un-surpassed roads & tracks data and possibly also Magellan?).
    Jon
    Highlands NSW
    This is a reverse question.... I have a garmin e-trex colour and am wondering what are best UK - Scotland especially - downloadable maps to put on my hand held?? Will be there in a month.
    2010 110 Crew Cab Deefa
    Mittagong NSW 2575
    Sydney, NSW
    Thanks guys, will take a look at Shonky
    Ive used Tracks 4Africa and know of people that use it. Im assuming its the same company/bloke. The concept is great, only publish tracks that have been verified several times by others. I guess the problem with OZ is that its so big and so getting several people using the same track and then submitting useful data is going to take time.
    Regards,
    Jon
