Results 1 to 10 of 30
Thread: D2 SLS Airbag replacement completed
    Jan 2008
    Grange, Adelaide
    On the Vic Toolangi aka Angus (thanks) trip in April I had some issues with the SLS.
    Today I installed 2 new airbags and a brand new compressor.
    Seriously a big fat thanks for all the good instructions and advice I picked up on AULRO on these items
    Since the Toolangi trip, I didnt have any more problems other than very slow to pump up the rear. I thought 9yr old airbags, hmmmm, just bite the bullet and replace them, so ordered new ones (from Arnott in USA). Then, after looking at WildOnes (thanks dude, hope the wedding was a blast) compressor inflating his D2 within 20 secs I began to think the 2 mins mine took was obviously pointing at a compressor issue instead. (yeah shoulda got the fault codes checked )
    So now I've ended up replacing the airbags and the compressor. Now normally the compressor is $900 alone and the LR genuine airbags $860 ea so a bit concerning....
    BUT... I bought the Arnott airbags at US$129 ea and also found on ebay a new compressor for US$200 ....add freight, I've replaced both these key pieces of equipment for $640 total. Now I'm really happy. This stuff will now see out the life of the car.
    20 seconds to inflate the rear.
    One very very happy D2 owner.
    I hope the attachment here can help others, its really a grab of all the stuff on AULRO plus my actual job experience.
    Thanks all.
    Attached Files Attached Files
    May 2003
    On The Road
    Nice Simon,,,
    Would make a good TUTORIAL,,,
    Had a bit of an issue with mine over the weekend,,
    running on or very near the bump stops,,
    it turns out,, that if you have a compressor problem,,
    all you need is a ten mm spanner,, plus a tyre compressor,, you CAN pump up the rear air bags on a D2,---
    more later,,,
    Brisbane, QLD
    Nice work Simon....glad to hear you have sorted out all your SLS issues.
    I'm very happy with the arnotts air springs as well.....great price, and speedy delivery.
    Since I've replaced them both, I've had no troubles yet. I'll be keeping an eye on the compressor though, as like yours it is over 9 years old, and has been compensating for those leaking air springs for a while too.
    Paul
    Jan 2008
    Grange, Adelaide
    Talking
    Pedro,
    Hope the SLS compressor hangs in there, but good to see the "bush fix" idea of using an alternate compressor.
    If you do need a new SLS Compressor, seriously look at the US or UK, with the exchange rates good at the moment its easy to land one into Australia for half the price of a local Oz one.
    Thanks also Caveman for the PM's on replacing the airbags.
    Still no sign of a leak.
    I also believe the ride is smoother, but that may just be my enthusiasm.
    May 2003
    On The Road
    its a real chicken and egg thing,,
    did the pump die from overuse?
    and was it the pump that was leaking?
    bags look and test fine, have not lost air in 3 days,,
    I would have bet big on the bags leaking which caused the pump to fail,, but it seems not!!
    Jan 2008
    Grange, Adelaide
    Had exactly the same confusing set of issues, first a warning light (on the Toolangi trip, and never came on since). Turned ignition off, then on, all ok. Parked car for lunch and the bum dropped all the way on the R/H side. Turned engine on and it pumped straight back up, then slowley leaked on R/H side the rest of the afternoon but so slow almost unnoticeable. Ahah, must be Airbag me thinks.
    Parked car on driveway overnight, in the morning still all ok and level , but compressor giving 2 or 3 lound buzzes nearly everytime the engine switched off (I now know this to be the death sound from the compressor) . Compressor now taking 2 or more minutes to struggle to pump the SLS up on OR mode. However in normal mode, the car still sitting level.
    Cleaned the SLS filter, no improvement, cleaned all electrical connectors, no improvement.
    by now the new Airbags had arrived, so figure they'll go on anyway but I was more convinced by now it was the compressor all along.
    Fitted the new compressor then tested and all 100% perfecto . Put the new airbags on since had em anyway, I'll keep the old ones as emergency back ups, they're old but were not the problem after all that.
    phew....Oh the personality from this vehicle.
    I'd start thinking about the compressor Peter
    Simon
    Alex Heads
    Have a similar scenario.
    Rear Drivers side was going right down occassionally.
    Now it seems to be doing it everytime the engine is turned off.
    As soon as the vehicle is on and engine running again, it will rise up straight away with no issues though.
    Is this likely to be just a leak/seal/connection issue somwhere, or something more serious?
    May 2003
    On The Road
    'Tis funny Simon,, mine always went down level--
    as for you Fen,,,
    (YES! its serious.)
    save your bikkies
    Alex Heads
    as for you Fen,,,
    (YES! its serious.)
    save your bikkies
    In the words of a redheaded redneck "AARggh, %(*^ it! Please explain!?!
    May 2003
    On The Road
    get a nice big spray bottle of soapy water,,
    crawl under the rear of the car,,
    spray soapy water over bags (in extended mode if possible),, then over air lines.
    easy to pick the leak on the bags and lines, if there is one,,
    or it could be the compressor dying,,,
    it seems mine has leaked back through the compressor,,,
