Results 1 to 9 of 9
Thread: How to remove Win2000 after XP install ?
    Having installed XP, I now have Win2k and XP.
    What I want to do now is remove the WIN2k bits.
    Any suggestions ?
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    Perth, WA
    Pretty easy to do, but as Win2k and WinXP have similar directory structures, we need to know where you installed both first? (i.e. Partitions/drive letters for each).
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    > FORMAT C:
    But seriously...
    Is it set up for dual boot now or does it just boot to XP? If that is the case and it doesn't use the W2K system then you simply need to delete the W2K directory tree.
    If it's dual boot you'll also need to remove the W2K option from the boot init.
    As mentioned, just need to know which directory is which windows version.
    Did you do an upgrade install and therefore migrate your application registry across? Otherwise you will have to re-install apps for XP.
    I would have liked to have done a format disk and clean install, but it wouldn't let me.
    I think this is because I was installing off the cd from Win2k
    I installed it on Drive C and yes, now I have a dual boot option on startup which defaults to XP.
    The laptop I am installing on does not have a floppy drive. Can you reset the boot sequence to read the cd first and do a clean format and install off the cd like you could with WIN2k using the floppies ?
    Quote Originally Posted by adm333 View Post
    Can you reset the boot sequence to read the cd first........
    Yes, you'll need to go into the computer BIOS on boot.
    .....and do a clean format and install off the cd like you could with WIN2k using the floppies ?
    Dunno, but it's easy to check.
    Kyabram, VIC 3620
    you should be able to set the boot sequence (ie boot from CD first)
    Depending on the chipset on the motherboard to enter the bios set up you either press DEL or F8 or somethimes F1
    But you should see a setup instruction when its booting to tell you which one
    Once in the bios just set the sequence as required,
    However ...............
    If you have the two OS's on two different volumes - this may cause issues.
    If you want to start from scatch - and go completely clean.
    Set to boot from CD = but when the system wants to install the new OS - click on cancel/exit
    You should then revert back to a C: prompt
    From here you can run fdisk - which you can delete/change/add volumes
    As said IF you want to start completely from scratch - all totally clear - delete all existing volumes - then set up one new volume.
    Once done - you can do a thoroughly clean install
    .................this method removes everything from your HDD - are you sure you want to do this
    Thanks for the tips.
    I know how to sort out the bios settings, just thought I'd check that it would work before I started.
    Its an old Dell laptop that I have with a few spare pull in, pull out hard drives. Thought I would set up a new drive so my son can play some games etc.
    A clean install from scratch is exactly what I want to do.
    These days I get frustrated pretty quickly doing home computer maintenance - when things don't work first time.
    Kyabram, VIC 3620
    Don't worry things never work the first time with WinDoze
    Kyabram, VIC 3620
