Results 1 to 10 of 20
Thread: Chassis number missing?
    TeZZaP Guest
    I'm just recording all the numbers off everything I can find on a reno project that I'm just starting... everything appears to be in order apart from I can't located the chassis #, its suppose to be left rear section above shackle plate isn't it?
    TeZZa
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by TeZZaP View Post
    TeZZa
    Tezza
    The rear location is usually true for Australian built vehicles after the 80" however, UK Built vehicles usually have their chassis number on the front RHS spring hanger bracket.
    This is a problem for vehicles that have modified/extended spring hangers as they will plate over the top of the number.
    Hope this helps.
    Diana
    TeZZaP Guest
    Thanks for that info, I'll check first thing tomorrow!
    TeZZaP Guest
    Still missing...
    Bugger, front of chassis has had some work done... no number there. I'm planning on de-greasing the chassis/axels/engine over the next couple of day (then its onto stripping off the last few bits and starting the making good process ), so if its elsewhere on the chassis hopefully I'll notice it!
    Do you think it will be an issue not having a chassis number stamped on the actual chassis?
    Sunshine Coast
    It certainly will be an issue. Especially if you are planning on getting the vehicle road registered. From personnal experience, QLD Transport take no prisoners where it comes to chassis numbers! They have more power than the police and it seems to me that every inspector is hoping to be the one to find a stolen or rebirthed vehicle.
    If you can't find a number on the chassis my advice would be to ask them for a surrogate number when the time comes for rego.
    hope you find that number,good luck
    ER
    I have been through this, albeit in NSW and a few years ago.
    You will have to clean the location down to bare metal to be sure it is not there - on the ones I have seen it is on the vertical part of the chassis bracket that hold the shackle pin at the back of the LH back spring.
    TeZZaP Guest
    Double Bugger! I'll double check both places (Rear LH + Front RH), I've given them both a manual wire brush back down to (almost) metal, enough that I thought any number should show... but I'll get into it hopefully tomorrow and get it back to 'real' bear metal... I'll let you know how I go!
    I do have the 'Manufactured by Solihull etc' plate, that states the Chassis No. Can I trace the history of the vehicle from that? [I also have a number plate, that I assume should have been returned...]
    1.20 MB
    It's very difficult at times and seems it relates to which apprentice was stamping the numbers that day. I think by the end of the day they were too tired to stamp very hard.
    Try with your wire brush and if you get a hint of a number go over it with some fine emery paper on a block. It can sometimes bring up the ridges around the edge of the digits.
    Also when you investigate, and if you haven't found it in the place specified by John, check the horizontal section of the rear bracket just below the chassis side rail. To see it you sometimes have to lie down on the ground and look up at the number.
    Hope your luck with the search improves.
    Diana
    Brisbane, Inner East.
    Restamp it. A set of number punches is not a great outlay for the trouble they will save you from dogmatic bureaucrats.
    URSUSMAJOR
    Oct 2003
    Godwin Beach Qld
    G'day TeZZap
    The chassis No is stamped on the outer verticle face of the front section of the Right Hand Chassis rail on the 110's and late Series 3's
    just behind the bumper mounting bolts, if the vehicle has been fitted with a bull bar or a raised chassis with the extra plates, they could well be hiding the stamped number, but it should be on your compliance plate on the front radiator panel, if it is a later series 3 (post 1979) it will have a number that reads like SALLB*******123456 If it is pre 1979 it will be something like 913 (4cyl pet CKD) or 918 (4cyl Diesel) or 943 (6cyl CKD)
    Hope that is of help
