We used to have one at a place i worked, it was basically a big bowl at the bottom with a flue coming out the top, it stood about 6 foot tall. you'd fill the bottom with old sump oil and throw in a bit of burning paper and off it would go. It had a little door on top of the bowl to fill it with and a sliding door with breather holes to control the burn rate.
Another mate of mine converted his coonara to run off old transmission fluid (he is a trans builder so had heaps of it), he tapped a small copper pipe into the back of the heater with a fine spray nozzle of some type and a small electric petrol pump to feed the fluid(it worked something like that, not 100% accurate now), heated his whole house (30+squares) for nothing.
