Thread: Help! TD5 Missing
    wjh958 Guest
    Help! TD5 Missing
    The engine is only firing on 4 cyls in my DiscoII. Probable cause is a faulty injector but I vaguely remember reading somewhere that there is a problem with one of the wireing looms in the TD5 getting oil into it that causes missfiring problems.
    Any pointers here would be most appreciated.
    Steve W. Adelaide
    Melbourne, AU
    What year is your car?
    do a search here under oil in injector or ecu loom - heaps of info
    could be fuel pump related
    in my 2002 model it was injector seal(s) - another search will help
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    wjh958 Guest
    Sorry, it is a Yr2000 model
    Steve W.
    Try here for oil in the harness.
    http://www.aulro.com/afvb/good-oil/2...l-harness.html
    Simon
    Goolwa SA
    The exact same thing happened to me last year. It wasn't oil in the external part of the injector harness but a fault in the bit under the rocker cover. Pray that it's the harness and not an injector!
    Stephen.
    2001 Discovery TD5 Auto.
    wjh958 Guest
    Thanks for the replies, very helpful.
    I checked the red plug that connects to the ECU and it is very oily so I guess that's what the problem is. It means a new harness, I don't know the cost. If it's an injector, my service guy has some second hand ones out of a fairly low km motor that I can get a lot cheaper than new.
    The car goes to him in a few hours, and then I'll find out what the damage is
    Steve W. Adelaide
    Somewhat North of Cape York...
    To change the wiring loom isn't a major problem. If you put in a new (or used) make sure it is the same type as the one removed as otherwise your ECU will need reprogramming to match the new injector.
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
