Results 1 to 10 of 11
Thread: Opening rear side windows for Series III
    Moruya Heads/Sth. Coast, NSW
    I have a 75 Series III 2 door enclosed back LWB LR, I am looking for windows that will replace the non-opening windows on the side of the rear canopy. Is there a LR opening window (sliding) available or is there a caravan style opening window that will fit, any info will be appreciated, Regards Frank.
    Brisbane, Inner East.
    Quote Originally Posted by Tank View Post
    The answer to both questions is yes. Station wagons had sliding windows. Caravan type opening windows were readily available.
    URSUSMAJOR
    May 2008
    Mundaring WA
    I was just recently wondering the same thing!
    Are the swb ones the same size as the lwb ones? I have seen a few sliding windows in the 88's. I want a pair too for my 109 Hardtop.
    Hate sleeping with no air!
    Cheers for the info
    Nathanial
    willvine Guest
    Yes, I have them on my series 3, I need to replace one, so I am also looking for a place to get them from.
    darwin, nt
    88" 2-3 rear window panels fit 109" station wagons, and vice-versa. I've also discovered that 95 110" station wagon panels fit. I don't think Defender 90 panels will, though.
    Thanks All for your useful info, Regards Frank.
    Quote Originally Posted by dandlandyman View Post
    No - basic dimensions for lwb are unchanged 1958 to present, and 88 rear side panels are the same size as 109/110 station wagon ones. But the 90 has a four inch longer wheelbase than the 88, and correspondingly longer body, so the side panels and hence windows are different.
    Williams West Aust
    Look for somebody converting a bus to a camper.They normally remove many of the windows during the fit out.Problem may be that they are too tall.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jun 2003
    Launceston, Tasmania
    I have seen defender ones fitted, but it must need some cutting as they are larger.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    MarknDeb Guest
    I measured the rear window panels on a defender 110 and they match the SWB 88 in all ways, best bit is the windows are sliding and larger so iam keeping my eyes open for a set of 110 panels to put on my SWB
