what are you going to pedal the whipper snipper???
exactly how are you going to use it?
john
Hi all not a landy thing but who knows i may use it when camping on the beach with the fendy, ok , what i am tring to make is a pushy powered from my old whipper sniper. what i want to do is weld a old bike peg onto the shaft which i hope is not allinium??? now the question i ask is how much care do i need to in taking all the fuel out of it so it does not blow up and leave me looking messy thanks all..
john
Easy.Fill the tank with water.Drain/clean flush with metho a couple of times asap after.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Depending on how fast you are trying to go, I have seen one that was made from an old lawn mower motor and a BMX, had a fair size gear on the back wheel too from memory. It went ok, but certainly not overly fast. I would think the whipper snipper motor would need some serious gear reduction.
A guy who lived near us use to have a whipper snipper motor on his bike and he would ride along the highway every day.
It seemed to get up to some pretty impressive speeds to
I'm interested in it so when you get going post some pics
CHEERS TIM.
thanks and will post some pics,
Why not take the fuel tank off while welding? They are usually easy to get off.
-- Paul --
| '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
| '94 Discovery Tdi 5spd man | going ... GONE
Gday all
When I was 15 I made a Victa Powered BMX Pushbike. I picked up a few Victa lamnmowers from the local tip and a BMX pushbike. I horizontally mounted the engine into the frame and used a skateboard wheel to run on the crankshaft. Victas have a tappered crankshaft and had a boss that pushed onto the taper.
I had a Suzuki RM 250 Carb on the motor and man it used to go. I was clocked by the copper in the town I lived in riding at 90km/h up a hill out of the town. I have photos of it somewhere.
The fun ended when I crash landed and broke my wrist requiring SS screws to be inserted in my wrist.
Rich
My little bro made a powered bmx by mounting the engine over the front wheel and used a skateboard wheel with grooves cut into it using and angle grinder to drive the front tyre, the bloody thing could keep up with traffic. There were 2 long brackets that attached to the wheel studs and another of the top of the forks somewhere. I have one of those scooter engines with centrifugal clutch here that i'm still deciding what to do with.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
