2nd June 2008, 09:50 PM
Whats about to fall off?
Hi guys, Just after a little advice on preventative maintenance. My auto TDi D1 is approaching 180k, I’ve owned it for the last 80 k. Has been serviced every 10k by a Landrover mob and is stock standard and in good nick. What do you think I need to start looking out for? Wheel bearings? Gear box has never been touched? Radiator? water pump? ......What do you think?
2nd June 2008, 10:18 PM
When was the last timing belt change done ?
Idler pully's can start making noises as i have just found out
Just keep an eye on simple things like hoses , oil levels , belts and
suspension bushes ...... other members will add some more info
2nd June 2008, 11:04 PM
Thanks;
timing belt was changed at 120k so I guess thats coming up again soon.
3rd June 2008, 08:48 AM
#4
A very senior chap at Land Rover australia says change the rubber band every 50,000k's "and don't miss".
URSUSMAJOR
