Thread: "Snap-On" Scanner
    May 2003
    On The Road
    "Snap-On" Scanner
    Had the D2 hooked up to one of these the other day,, The workshop owner brought it out from England when he emigrated. He has the "England" D2 cartridge and the correct KEY (being a Land Rover nut )but this would not talk to my D2.
    Anybody had dealings with this type of scanner?
    Williams West Aust
    My Bros mechanic mate has one.
    He has only bought the licences to the common Aussie cars he deals with and has no Landy accses.
    I wonder if the one you tryed is only open to UK spec Landies???
    Kens mrs brought an OBD11 scanner(unsure on the brand)home from work(she chucks spanners for a living) to get into his D2 V8 when it was playing up,they were able to read/clear faults apparentley.
    Im guessing being a caryard scanner it was unlocked to multi franchises!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2008
    Horsley Park, Sydney
    I have used a snap on scanner on my 06 Defender - reset a few stored alarms, checked ABS sensors etc - not sure of all the volyages and graphs shown. I only played with it for half an hour - seems very good - very expensive though. You must have the correct software load and the correct Land Rover hardware key to use this particular unit. I am going to borrow this again in a week or so to have another play.
    Cheers, Erich
    May 2003
    On The Road
    Welcome Erich
    This one was red and had black rubber ends??
    He had the right cartridge,, and had "a" key to put in--
    but it just wouldnt talk,,,
    would have been nice to have one just down the road!!
    May 2008
    Re the scanner. Could you set it up through the pages - European cars - Landrover - Defender - 2002-05 Defender, before plugging in. Then plug in, wait for coms and turn on the ignition.
    The snap-on scanner I used appears the same as the one you used - red with black soft ends.
    I just went through the ABS to see the data outputs and was surprised at the amount of data. I assume it is similar to some of the other scanners around. The following can be read: 4 wheel sensor outputs, 4 wheel speeds, pump supervision, groung ref, the 8 ABS valves, pump relay, brake relay, valve supply, ignition voltage, clamp control, throttle position, engine torque and shuttle valve switch.
    Cheers, Erich
