Results 1 to 10 of 16
Thread: Wireless network gurus - please help!
    Jul 2007
    Two Rocks, W.A.
    Hi all
    My wireless network is driving me to distraction!
    In brief: had a laptop, set up wireless, was never overawed with its performance but was ok-ish.
    Laptop died, bought desktop, scrapped wireless, just plugged ADSL modem straight into desktop.
    Get laptop repaired, thought it would be a good idea to re-instate the wireless, so...
    What is doing my head in, is IE and Outlook.
    Keep getting "Send/receive" error and "IE cannot display page" messages, but on second or third attempt the page will load, sometimes slow, sometimes fast. What the? No issues with the modem direct connected - so I assume must be the WiFi.
    Hardware/software:
    Desktop: Vista, 2.2GHz core duo, 2 gig RAM, 230 gig hard disk (74 gig used)
    Laptop: XP SP2, 1.6GHz centrino, 1 gig RAM, ~160gig hard disk
    Wireless router: D-Link DI-524UP
    ADSL Modem: Alcatel SpeedStream
    Connection: 1500/256
    N.B. both machines running Norton Internet Security '08 packages.
    Any ideas if this is a settings issue or is the D-Link better used as a wheel chock?
    Have some understanding, but clearly not enough!
    Mike
    '00 D2 Td5 'Alice'
    '03 V6 Freelander 'Phoebe'
    '04 Td4 Freelander 'Harry'
    The first thing to do is check for interference. If your wireless router is right next to the microwave, or the cordless phone base station then the problem should be easy to fix.
    If you're running 2.4Ghz cordless phones, then you need to change the channel that your wireless router is broadcasting on.
    Next thing is to set up the laptop and wireless router next to each other to rule out interference problems. If you get a great signal when they are real close then something is stopping the signal, move the wireless router, play about with the aerials, raise the whole thing high on the wall, etc.
    Check that all the drivers/firmware is up to date on - wireless router, wireless card in laptop, etc.
    Check that you are running SP2 for XP.
    Make sure you don't have two DHCP servers.
    Umm, can't think of anything else fun at the moment.
    Simon
    Oct 2007
    If all you use it for is reading emails and looking at webpages, nuke windows and run Ubuntu. Its free, secure and faster than windows.
    We have a dlink 624p+.
    We've had it for a few years and it's all been ok. Then sort of slowly our cable seemed to be slowing down and we were getting dropouts. We got the telstra guy out and he said it was our router (long story but unbknowns to me Telstra had turned off the password/heartbeat system). So, we've now got a new apple router and all is good again in the world
     2005 Defender 110 
    Jul 2007
    Two Rocks, W.A.
    Thanks Simon...
    The first thing to do is check for interference. If your wireless router is right next to the microwave, or the cordless phone base station then the problem should be easy to fix. Router is approx 5-8m from each
    If you're running 2.4Ghz cordless phones, then you need to change the channel that your wireless router is broadcasting on. yep, pretty sure they are 2.4 GHz Uniden WDECT
    Next thing is to set up the laptop and wireless router next to each other to rule out interference problems. If you get a great signal when they are real close then something is stopping the signal, move the wireless router, play about with the aerials, raise the whole thing high on the wall, etc. ****not sure that it's signal that's the issue as the desktop has the problem too and that is direct connected to the router****
    Check that all the drivers/firmware is up to date on - wireless router, wireless card in laptop, etc. hmmm, no haven't done this
    Check that you are running SP2 for XP. the laptop is SP2
    Make sure you don't have two DHCP servers. ???
    Mike
    '00 D2 Td5 'Alice'
    Of course it could be a security thing and some local is using your wireless connection and you just can't get through to it.
    So check security setting and check out your isp website that should have a section to show you how much porn you've downloaded this month. Usually you can tell that there's an extra 500Mb a night that you don't remember asking for.
    Simon
    Quote Originally Posted by 2 rocks View Post
    Thanks Simon...
    Mike
    If you're with Telstra turn off the "Telstra Heartbeat".
    Bayswater, Melbourne
    mmmm, sounds fishy to me
    First up -
    "N.B. both machines running Norton Internet Security '08 packages." Sorry - if your with Optus & got it for free.. well there is a reason is FREE! Second, if you bought it - you got ripped off. Sorry Norton internet security slows down computers on a whole about 45% from memory & causes more problems then it solves or stops Thats my professional thoughts on it lol
    Second: -
    Are you sure your getting connection to the wireless network?
    How to tell - if you are getting a correct connection - you will get an IP address. An easy way to see if you got one is to do the following:
    Click on the "Start" button
    Click on "Run"
    Type "cmd" and then click OK
    A DOS box should appear
    Type: ipconfig /all
    This is what mine shows:
    C:\Documents and Settings\RaZ>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : razzor
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Intel(R) PRO/1000 CT Network Connection
    Physical Address. . . . . . . . . : 00-11-2F-57-BD-B8
    Dhcp Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    IP Address. . . . . . . . . . . . : 192.168.1.3
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    DHCP Server . . . . . . . . . . . : 192.168.1.1
    DNS Servers . . . . . . . . . . . : 192.168.1.1
    Lease Obtained. . . . . . . . . . : Thursday, 5 June 2008 4:35:00 PM
    Lease Expires . . . . . . . . . . : Friday, 6 June 2008 4:34:58 PM
    I have noted the sections in bold that matter - if your not getting your IP from DHCP (Wireless router) then your not getting the correct connection or if you don't have a "Gateway" IP set your still not going to go anywhere.
    mm, just read your getting it on the lappy & the desktop - so try that on the desktop first
    make sure your getting the IP details you need - gateway IP should be the router IP so it can send data out to the internet
    **EDIT: Security - log on to the router & make sure its not restricted to only giving out 1 IP - also check the status page on the routers setup & make sure its connecting to the adsl modem correctly?
    ***EDIT: Stuff about security from the makers web site:
    Access control is provided with packet filtering based on port and source/destination MAC/IP addresses. With Virtual Server Mapping, the router can be set to allow separate FTP, Web and multiple games to share the same Internet-visible IP address while still protecting your servers and workstations from hackers. You can configure any of the built-in LAN ports of the router to function as a DMZ port. Parental control allows you to filter out undesired URL web sites, block domains and control the time of day of the use of Internet through scheduling. VPN pass-through is provided to let mobile users access files and mail from
    offices to work at home without having to use complex VPN client software.
    So for testing sake - make sure security is turned off
    only other thing I can think of is to make sure you have the cable from the modem going to the WAN port on the router WAN = Wide Area Network aka port for internet
    Good luck
    Ah, okay just read your reply.
    So the same problem is happening on the desktop connected via ethernet? From your first post I thought the opposite was the case.
    The problem could be the Speedstream modem. Is it a Thompson 520 or something?
    Bejiggered if I know, but I've found a few Telstra modems that overheat and go funny.
    Get your modem control panel up in a web page and get the connection status up and see if it keeps disconnecting itself.
    If so, either call Telstra and get them to send you a new one. Or, take off the plastic top of the case and give it a bit of air, you can still run it like that. Or stick a heatsink to the hot bit and close it up again.
    Simon
    I am on the chat btw :P figured if we are all online :P
