Results 1 to 4 of 4
Thread: odometer light
    Apr 2007
    near the barrossa
    odometer light
    It seems my 2003 d2 has reached the time in its life where the dash lights want to die one at a time. I replace the clock light a couple of months ago, now the red and blue heater control button has gone , looks fairly easy like the clock but the odometer light went at the same time, this looks more complicated, any tips would be greatly apreciated
    Cheers Keith
    Apr 2007
    near the barrossa
    looks like I may be on my own here
    Thanks anyway
    Cheers Keith
    mike 90 RR Guest
    Quote Originally Posted by keith View Post
    Thanks anyway
    Cheers Keith
    Na ... not really
    Can't give you a tip cause i haven't done one for your's
    Have ripped a Ford dash apart and the RRC
    Just follow the path of the screws ... and be quick to diconnect the battery if
    you have to pull out circuit connections
    Cheaper to have a disconnected battery than have shorted wires
    Mike
    Williams West Aust
    Be very wary of ANY YELLOW WIRING.
    These are the SRS wiring,it is possible to set the airbags off messing with the wiring whilst the system is active.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
