Thread: two active vista partitions--
    May 2003
    On The Road
    and I wish to get rid of one of them,,,
    "disc management" wont let me do it,,
    as far as I can see, there no facility if you boot off the dvd,,
    any ideas?
    I thought Vista could do that stuff.
    There was a good thread covering something similar recently.
    Simon
    Kyabram, VIC 3620
    Would it be possible to go in from good old DOS - and either do a fdisk - or even a basic format to clean out the OS from the volume you don't want.
    After a format - you may find you might be able to remove the volume using the disk management within Vista
    Just a thought
    Start>Run and then type MSCONFIG
    You can then disable the other partition.
    May 2003
    On The Road
    yep,, takes me to system configuration,,
    cant see anything there that could help,,
    in BOOT
    there is nothing to alter,,,
    You should be able to alter the Boot menu (Boot.ini settings).
    I'll have to fire up my laptop to check, don't have this problem with a Mac
    Second half's started so will have to wait for NSW to get flogged
    May 2003
    On The Road
    and they did,,,,
    Lead you astray run BCDEDIT.exe in Vista (Boot Configuration Data Editor)
    What a great score at the end
    This is the thread I meant-
    http://www.aulro.com/afvb/computers/56579-vista-xp.html
    Mostly Lada's post-
    http://www.aulro.com/afvb/computers/...tml#post745359
    Might not be much help.
    Simon
    May 2003
    On The Road
    BCDEDIT.exe
    yep,, stores etc
    vista says it will "run with admin privledges,,"
    but then nothing opens/happens,,,,,
    What a great score at the end I exited stage left at 24
