Results 1 to 9 of 9
Thread: P38 Air Springs / bags?
    Dean Guest
    Wink P38 Air Springs / bags?
    Hi,
    I'm hoping some of the more informed help me with a little advice please?
    Can anyone point me in the direction of an Australian supplier of Arnott III front & rear air springs.
    HRA advertise but do not supply them any more and I have not seen anyone who stocks and sells them in Australia.
    If you know of a viable alternative this would also be appreciated.
    Many thanks
    Dean.
    olemandave Guest
    Dean, I to am looking to replace my air springs. I have contacted Arnott in the US and have been quoted $828 AU + $107 ( express ) $58 ( priority ) delivery for a set of front and rear replacement units.If you require just the bellows,(genuine Dunlops ) The AirBagMan in Brisbane will supply these for $195 each + delivery.
    Welcome to Airbag Man
    Air Suspension Kits, Parts, Struts, Air Suspension Bags and Pumps - Arnott Industries
    Range Rovers
    Atlantic British - Land Rover Parts & Land Rover Accessories | Range Rover, Discovery, LR3, LR2, Defender, Freelander and Land Rover Series Parts & Accessories
    These sites are worth a look with the strength of the aussie $
    Dean Guest
    Wink Great advice
    Thank you your feedback, I have gone to Arnott and requested a quote.
    Dean
    May 2008
    Hi guys - curious as to how you went with the Arnott airbags?
    I'm looking to change over the bags on my '95 P38A HSE as the LH rear bag is perishing and figure I might as well change 'em all over for something a bit stronger and better for offroad. The Arnott Gen3's look like the go.
    Interested to hear your experiences in buying them, and if you've had them fitted yet.
    Paul.
    May 2003
    On The Road
    dont they make overlength ones for the rangie?
    olemandave Guest
    Just a quick update, the air springs arrived from Florida within six days as too the shocks and pollen filters from New York. All i need now is to install these ( a big ask from a guy who makes teeth for a living ! cheers
    May 2008
    Quote Originally Posted by olemandave View Post
    Hi olemandave
    my Arnott Gen3 air springs arrived last Friday (about a week delivery from Arnotts in Florida) and are being fitted by Canberra Motor Works. I should have the Rangie back on Monday and am looking forward to the comparison with the old standard air springs.
    I haven't gone with new shocks just yet so will be interested to hear how you go with yours. Did you go for longer shocks to take advantage of the longer reach of the Gen3 air springs?
    cheers and best wishes
    Paul.
    olemandave Guest
    Quote Originally Posted by PaulP38a View Post
    Hi olemandave
    Paul.
    Hi Paul. Great to hear everything arrived as expected. As i purchased this vehicle new eight years ago i have confess , beyond a little beach driving i have never used it to its full capability hence its still in showroom condition. I must admit i didnt consider longer shocks to take advantage of the increased travel of the springs for this reason, and was under the impression standard length would include the auto lift height if the body was grounded . Would this then reflect to adequate travel for the shock / spring ? On another note ( and probably should be in another thread ) after vacuuming today i found the heater O rings have failed again. O well it wouldnt be a Range Rover if i wasnt spending Money .
    Regards Olemandave
    May 2008
    Hi Olemandave - think I got a bit carried away and confused by various magazine articles about extreme suspension mods to Discos, RRC and Defenders (but never a P38A)... I'm pretty sure the shocks aren't going to be a problem with the Gen3 air bags.
    I got my Rangie back today and Ray over at Canberra Motor Works informed me that the car now sits approx 35mm taller on "offroad/extended" height. And it feels it too, or perhaps it is just that I've been driving a Ford Laser around for the past week! Normal height is same as before as I can still drive the car in under the garage door at home.
    Ain't that the truth. After chasing a "flat spot" in the performance of mine recently, we've gone through 2 Crank Pos Sensors, head gasket, 2 catalytic converters and a fuel pump - all were bad but it seems that the fuel pump was the culprit. Just as well I'm expecting a refund on my tax return real soon.
    Cheers, Paul.
