Results 1 to 10 of 15
Thread: Black Friday Stories
    Williams West Aust
    Last nite over a few beers,Hippie the gardener told us we shouldnt be working today (RDO=Good $$$$).
    Well it turned out he was right.
    Roller driver wanted the day off so another worker took his place.I get grading and he turns up in the ute,radiator cap was missing from the roller and no water,off he went to get some water.
    Got to the end of the run,he says I better come for a ride in the roller,sounds like the bigends are ratteling.Sure enough a hell of a rumble.I noticed the chimney was mooving more than normal,sure enough the bolts had fallen out of the mount and was chaffing the injector return line.We pinched a bolt to do a temp fix.Was close to smoko time I pulled up next to him turned the grader off so I could here him,told him when he gets the roller going and catches up we will have smoko.Went to re-start and the key just turned and nothing could only get the dash to light up.Tried shorting the starter motor with the dash on(ie power to computer) could only get the starter to wizz over no engagement.
    The barrel was to be replaced on mondays service as it was throwing error codes over the last couple of days.So unable to start the grader parked in the middle of the road had to wait 3 hours for new lock barrel to come down from Perth.
    The techie said even if I tricked it into starting via the starter motor,which he says should be impossible the computer requires a prompt from the ignition barrel to enable unlocking the transmission,a theft prevention innovation!!!
    Double time sitting arond a campfire for 3 hours!!!
    Any other friday the 13th bad luck stories????
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Kippa Ring
    Day started with a concrete truck dropping bits of dried concrete the size of half a house brick on the road in front of me to dodge and ended with the drive from our depot near the airport to the gateway motorway taking an hour, when its normally a 5 minute drive.
    Am starting to believe in supersticion (is that how its spelled ???)
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    Quote Originally Posted by jbarracl View Post
    Superstition
    (filling in for Ron)
    Brisbane, Inner East.
    Superstition
    Brown Nose!
    URSUSMAJOR
    Allestree , its all good.
    How bout the good stuff going up to $1.92 per lt, filled the work tanker up thismorning at $1.87. But by the time I got back thisarvo to top up the defender the price had gone up.
    $215 spent in less than 5 mins.
    Thats black Friday for you.
    I do know others are allready paying that price, but it means that tonight Im drinking a blend not single malt.
    '99 Tdi 300 130 Twin Cab
    When I'm here I want to be out there.
    Kippa Ring
    Quote Originally Posted by Sly View Post
    Glad you reminded me, must go have a Jamesons
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    Boonah, QLD
    I went to wind down the window in my kingy this morning and the black knobby bit that you use to do the winding broke clean off !!!
    I was not a happy camper...
    Driving around all day, everything fine - Subaru, not Defender.
    Out for dinner, load everyone into the car, taking a drive to pick up some hubs I won off ebay unannounced and get the kids to sleep.
    Speedo doesn't work, fine we can live without.
    Friday night loonies run every single red light between Leichhardt and Granville on the Parramatta Road.
    The bloke isn't home - that doesn't really count, I didn't call until we were a block away.
    The kids didn't fall asleep.
    The Check Engine light came on halfway home and didn't go off.
    Still haven't fixed the Defender, so back to zero cars for a while.
    Simon
    Warragul, Victoria
    Refereeing a Paintball game today.
    Group turned up earlier than expected and I rushed to get them out on the field.
    Forgot 1 bit of safety gear-The Cricket Box.
    Guess where I got hit in the first 30 seconds of play
    IT HURTS IT HURTS IT HURTS
    PS, No Pics
    Williams West Aust
    Wait till tommorow then we want the pic as without pics it didnt happen.
    BLACKnBLUE
    Good job the mud pit was canned
    Andrew
