7.0 Using Mapborder
- Start the Mapborder application.
If Oziexplorer is not already running, Mapborder will attempt to start it.
If Mapborder does not know where the Oziexplorer application is, it requires you to manually start it-
This is required once only, after this, Mapborder will know where to find the Oziexplorer executable for the next time.
If you have renamed the Oziexplorer executable (oziexp.exe), Mapborder will never be able to start Oziexplorer itself (you will thus need to start Oziexplorer manually first).
[Load Folder] is similar, but will sequencially load all map files found in the specified folder.
Thus saving you the trouble of loading many map files one by one manually.
It is best for you to first become familiar with Mapborder and the Load Map operation, before trying Load Folder.
- Select the .MAP file that you wish to modify.
If you wish to make a few minor changes to the existing border, click the
[Load Original] button, and you will be presented with the original border that can now be edited.
At least four corner markers are required before the
[Save MAP] button becomes active.
Up to 100 points can be entered. The program will beep, and stop adding points once 100 has been reached.
At this point, only the
(move),
(Delete) and
(Edit) functions will be available for selection.
The border you draw must not have any
crossed lines, it must encompass the map area of interest
(example1) (example2).
- Once you are finished, click the [Save MAP] button.
It is at this time a backup (if requested) is saved, and the new changes implemented into the .MAP file.
The changes should become visible immediately.
- Once you exit the Mapborder application, if any backup files had been created, you will be asked if you wish to delete these.
Clicking yes will delete any backup files created during that session only.
This enables you to clean up afterward, if you had not intended to back up MAP files anyway.
Anything you had changed in the [Configure] tab(s) will be saved to the INI file.
The Mapborder application will also save its position on the screen to the INI configuration file.
The next time you run Mapborder, it will be positioned in the same place you left it.
The very first time you run Mapborder, it will be positioned in the centre of your screen.
If you position Mapborder off the edge of your screen, it will be moved to the centre the next time you run it.
