A lot of work.
Fit a transfer case - and the Series case I do not believe is a bolt on fit - anything else that is a bolt on fit is set up for full time four wheel drive, which means either converting the front axle to suit this or converting the transfer case - both are major jobs.
New prop shafts, front and rear - the gearbox length is different. Rear prop shaft may be getting a bit short for comfort, depending on the transfer case.
Design, make and fit new handbrake linkage.
Design, make and fit new floor and transmission tunnel panels.
Modify seat box for new floor.
Design, make and fit new gearbox mounts.
If the box fitted is off a 200Tdi, then the bell housing should fit - if not, it won't.
In summary, it can be done, and probably has been when fitting a later engine, but would be an awful lot of work.
