So you have bled BOTH of the small bolts on the IP???
Using the hand primer?
Afer making sure there is no air left in the IP, I just loosen all the injector lines (on the injectors), and crank the engine over until fuel is spurting out all 4.
Then tighten them back up and it should start fine.
