Results 1 to 10 of 18
Thread: Wheel spacers for FCs
    brookvale Guest
    Greetings from the East Island.
    What's the received wisdom on installing 25mm (30mm?) wheel spacers on an FC (or any LR for that matter)?
    Cheapish option to keep standard rims...
    Improved track width (is this really a good thing?)
    Loss of turning circle?
    Too much strain on steering/axles/swivels?
    Improved or reduced steering load/action?
    There's a set of 24mm spacers for sale at NZ$550 at the moment (reduced - hah!) from $650.
    Comments?
    Neil - 65 IIA FC
    Brisbane, Inner East.
    Unless fitted as original equipment, their use is forbidden in Australia.
    URSUSMAJOR
    As Brian says they are illegal in Australia, but you need to investigate their legality in NZ.
    Improved track on a 2a FC is probably an advantage (one of the differences with the 2b), but steering would be heavier, and it increases the load on the wheel bearings, swivels, axle housing, steering gear - all of which except for the bearings, were upgraded on the 2b.
    I would not consider it. There are probably good reasons why wheel spacers are strictly illegal in Australia, most likely because of poor quality ones resulting in failures. They are a very highly stressed part, which is critical to control - are you certain they are up to it? (and the loads on the wheels are quite a lot higher on the FC than on bonneted Landrovers that they were presumably designed for)
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by brookvale View Post
    Comments?
    Neil - 65 IIA FC
    Welcome to the AULRO Neil
    Don't pay too much attention to Brian, he doesn't fully understand the notion of the Eastern Isle. He's probably thinking Russell Island, Stradbroke Island or Bribie Island. (But his Land Rover knowledge is usually good!)
    Wheel spacers are illegal in Australia, but wheel adapters are apparently legal. (but don't quote me on that.) The adapter being bolted onto the hub then the rim bolting onto the adapter with a different set of studs and nuts.
    You would have to check the various regs in Kiwiland. But the adapters are a much safer device.
    Now to the issue, the original rims on your SIIa FC and the suffix A SIIB's are supposed to have a neutral offset. That is the projected line of the Kingpin inclination (a line running through the centre of the top and bottom swivel pin bearings) runs through the centrepoint of the tread on the road. This is the point where the steering geometry is correct and resistance least.
    That said, the SIIB suffix B and later rims (569203) were manufactured with about a 20mm positive offset (widening the track) to correct a clearance issue with snow chains on the rear spring hangers. Your using the wheel adapters would achieve the same effect although a bit more positive offset.
    Yes a wider track should make the vehicle a little more stable, although other devices like anti sway bars similar to those on the SIIB front axle would also help. If anything you should be able to decrease the turning circle by adjusting the stops. Although this can put more stress on the front axle spicer joints on full lock.
    The question is, would you be able to find a set of 569203 rims for NZ$550 and avoid the need for the adapters? Possibly.
    What do others think?
    Diana
    P.S. Hows that new 3.9 V8 going?
    brookvale Guest
    good stuff guys - it's what I need to hear.
    I should have said 'adapters' and not spacers.
    These things are either alloy or billet steel rings - bolt on and then bolt on wheels to the new studs
    advert here
    All up I should probably leave well alone. The point about the loads on those front wheels is taken... my steering is heavy enough as it is
    The new 3.9? - brilliant! still sucks lots of petrol though... Interesting that a mate on the 1000 mile run to LR60th event in his StageI got slightly better mpg than me - on 95 octane. But.. FAB is way heavier than his truck so we were about quits and I was on 91.
    I still have to tinker with the throttle lever bell-cranks on the manifold - the action is too stiff and fast for decent control off-road.
    Re: steering - New thread option - how to refurbish a steering relay?
    Neil
    Diana, I am aware he is from that small group of islands where they speak funny, the eastern suburbs of Tasmania, where they have a national leader called Hullen.
    And Qld. Transport say adaptors and spacers are the same thing in their view and illegal unless original equipment.
    URSUSMAJOR
    1.20 MB
    Quote Originally Posted by Brian Hjelm View Post
    Yeh I've always thought those people are a bit unusual - now I know they're East Tasmanians it makes sense!
    About the spacers/adapters. That was what I always thought, until recently at a friends workshop. (His brother-in-law brings in Equipe accessories.) When I saw a set of adapters on the bench I suggested they were illegal. He suggested I was wrong and that only the "spacers" are illegal. Hence my comment not to quote me.
    I guess it would be a case of check with the registering authority before you buy or do the safe option use the standard rims off the later model (569203).
    Diana
    Newcastle
    i have a set (30mm) on my missus disco and have ordered another set for my county.
    they are the duck's nut's and whilst being illegal to have them on, on the road who's going to know.
    if you have an accident just whip them off before the insurance assesor see's the car as your normal pc plod isn't going to notice them on anyway.
    there's plenty of car's driving around with illegal mod's much more serious than a set of spacers
    they give you back your turning circle and a bit more with bigger tyres, more articulation, they give the car a better stance and more stability on cornering.
    as for stresses and strains - no more than a set of 35's - probably do wheel bearings more often, but won't do them at a rate quicker than you'd notice, anyhow -big deal they're not that expensive anyway and just because they are illegal in oz doesn't make them dangerous as they are not illiegal in other countries
    if your happy with the price i say go for it - once on you'll never want to drive again without them
    you can get them from the u.k. for about $300AU landed
    jason
    1.20 MB
    Quote Originally Posted by taff View Post
    ...as for stresses and strains - no more than a set of 35's -...
    ... jason
    Jason
    Just a note on Land Rover Forward Controls like Brookvale's, they already run 9.00 16 bias ply (= 255/100 R 16) which is almost a 36" with a 9.00" width and no power steering.
    Diana
    brookvale Guest
    Just searched and found local NZ regs say:
    Fitting of or modification to: LVV certification is not required provided that:
    Aftermarket wheel fitments • the wheels:
    – are a known and reputable brand non-OE item, and
    – would be considered an appropriate fitment for the vehicle type by the wheel manufacturer, and
    – are not modified, and
    – spacers or adaptors are not fitted.
    Certification cost anywhere from $450 upwards depending on the modifications.
    I'll not muck around - I'll stick with vanilla LR rims...
    Neil
