Results 1 to 10 of 16
Thread: bummer!
    pcamm Guest
    bummer!
    g'day guys good to be here .
    only just got my first car /first rangie <1990 classic> about a month ago
    and i was just wondering what some of u fellas would do with the old girl now she does'nt look so hot?
    Highlands NSW
    Buy another one and use the mechanics for spares.....
    2010 110 Crew Cab Deefa
    Mittagong NSW 2575
    Coogee, South of Fremantle, WA
    I have to ask, what did you do to it? I hope all involved are ok.
    I agree, buy another and break this one for spares if you have the room.
    pcamm Guest
    everyone is ok thankfully , was waring thongs and i cld'nt lift the accelerator off the floor also the front and rear brake pads needed replacing so thay were'nt much help . the new brakepads arrived a day or so after the incedent.
    went though a very hardy steel fence.
    Melb. Vic.
    If the chassis/mechanicals are ok - rebuild it. Look for a donor RR with reasonable panels (easier said than done!) and a blown motor. Should be able to get something for couple of grand or less. What happened to it??
    Yinnar South, Vic
    If your in Vic, sell it to me for a $1000
    Rangier Rover Guest
    Or, if you are in NSW sell it to me. I might need the spares for my 89
    Avoca Beach
    On first sight most of the damage is cosmetic, although you sure did a thorough job on damaging most of the panels.
    The doors seem the best, although its hard to tell from the photos. Are you aware that all of the panels are bolt on? You can DIY replace nearly all the panels .
    Ie the rear guards and corners are held by self tappers inside and a few rivets. The bonnet of course, the plenum panel, the front guards etc etc.
    A wrecker like Graeme Cooper may have quite a few of the panels.
    This is as long as you have not damaged the turret inner structure or the uprights inside the rear corners. if so you may as well write it off.
    The most expensive bits will probably be lights.
    Regard s Philip A
    Highlands NSW
    Quote Originally Posted by pcamm View Post
    Glad no no one was seriously injured ......
    Mittagong NSW 2575
    Hobart Tasmania
    As mentioned above, buy another one and with the two build a good one
    Carlos
    1963 Land Rover Series 2a 88
