Results 1 to 10 of 15
Thread: Calculating cells between separate MS Excel files?
    Gold Coast, Qld
    My excel abilities are self taught and learnt as I go, plus have picked up lots from asking q's on AULRO, but just stumbled across an anomoly which, if possible, will open up a whole new world of efficiency.
    Q. Can formulas calculate between separate spreadsheets/files?
    I am using Office 2007 and I simply copied a bunch of cells into another file with a view to reformatting them for my new spreadsheet and changing the formulas to suit, but noticed that the copied cells were still calculating back to the file I had copied from
    So, if it is possible to calculate between spreadsheets, would I simply have the files open I want to calculate from and set formulas that way or is there an easier/safer way?
    All comments appreciated.
    I really should go and do an excel course
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Feb 2005
    not sure that you can do it across differant files.....i guessing you know you can do it across the differant sheets/tabs at the bottom of the page
    Quote Originally Posted by MickG View Post
    Yes. When you reference a cell in another spreadsheet or another tab within the same spreadsheet, it's called a link.
    It is easy to accidentally create these links when copying from one sheet to another.
    You can edit, update and delete links as required.
    If you do reference another sheet in a calc, you will be asked to "update" the data when opening the spreadsheet.
    Deleting, renaming or moving the linked sheet will cause errors in your calcs.
    Gold Coast, Qld
    Bingo, so if my files are left in their loaction, unchanged and it is simply cell vlaues that changes, the calculations between files once set up will remain?
    Do I simply open the files involved, and set the formulas up this way?
    Weeds, yes formulas between sheets/tabs are no probs, thanks.
    Aye, Mick
    Yes.
    Say your sheet with the calcs in it is the Master and the sheets with the values in them are Sources.
    You can change values in the Source sheets whenever you want to.
    When you open the Master you'll be asked to "Update links" or some such. Click Yes and Excel will retrieve the current info from the Source sheets.
    Linking sheets works well, you just have to be anal about file names and locations.
    East-South-East Girt-By-Sea
    1.20 MB
    What WhiteD3 said and you can even copy the spreadsheets to disk or memory stick so long as you keep the filenames and path on the media the same as on the machine (or you correct the link in the spreadsheet).
    Diana
    Redbank Plains
    I think we need to have an Excel course over a few beers young man
    With both files open you can reference back and forward between them the same way you do with sheets. I.e. click = select required file/sheet/cell and hit enter. Calculations/Lookups work in the same way. While both files are open the formula will refer to the file name, if the second file is closed the formula will refer to the file name and location i.e. C:/micks stuff/test.xls
    Example:
    ='A:\Daily Manager Reports\WE 28.06.08\[Rep Performance Summary Report (28 06 08).xls]Daily State Summary'!$K$7
    File is located on the A Drive under folders Daily Manager Reports -> WE 28.06.08, File name is Rep Performance Summary Report (28 06 08).xls and the data is in cell K7 of the Daily State Summary tab/worksheet.
    Just call your excel helpddesk if you need any help
    Quote Originally Posted by stikman View Post
    Tried that once but my Punjab-e was a bit rusty.
    Gold Coast, Qld
    I need to start paying you guys a consultancy fee Yes, a training session would be good Philippe.....I will eventually do a proper one, (not that your teachings would not be proper) but next question is, do I do the novice or intermadiate course
    Thanks for the help guys....now to spend the next 2 weeks modifying all my spreadsheets for the next fin year
    Aye, Mick
    Alex Heads
    Mick,
    In a previous life, I also taught Excel among other things. Pretty sure I still have the discs and workbooks, (basic though to advanced), If I can find them I'll get them to you. Still used to get updated course material sent to me, I think the last ones I received were only about 18 mths ago.
    Now to find them
