Results 1 to 10 of 13
Thread: lpg mixture settings
    Mar 2007
    Birnam Range, qld
    Hi, where the hose goes to the mixer on the engine theres an aluminium adjuster in the line. would anyone know if there is a way of setting this by ear so to speak. done a bit of searching and found some great stuff on idle mixtures etc but nothing relating to this bit, hope you can help
    thanks
    neil
    99.87 MB
    I'm not sure how others do it, but we use(d) an exhaust sensor to give us the fuel/air mix
    Slunnie
    Brisbane,some of the time.
    i think this is the main mixture screw....it has to be set using an exhaust gas sensor & preferably having the car on rollers.if it is not set correctly you will have all sorts of trouble including possibly burnt valves
    the screw on the gas converter may be the idle mixture,which is also set using an exhaust sensor
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by neil 90 View Post
    Hi, where the hose goes to the mixer on the engine theres an aluminium adjuster in the line. ...
    Ooh! I didn't know that you had to adjust the aluminium in an LPG system?
    Having only watched as this was "tuned" Slunnie is correct, you need an exhaust analyser to do it. Too rich and you are wasting gas and too lean you lose performance and risk burning exhaust valves.
    Diana
    Melrose SA
    I was always taught to run it to 3000 rpm adjust the mixture until it ran smoothly then wind it out half a turn.
    The purists would say that you need all the equipment but this is how most workshops in Australia (read 75% of them) will do it when you book it in.
    Duane
    Dalby
    Quote Originally Posted by djam1 View Post
    Duane
    You will find at least one thread on here from me when I was learning about LPG tuning.
    I did as above and trust me that you will know all about it if it is running lean. Quite simply you will have no or greatly reduced power.
    Since you are not starting from scratch and it runs etc as it is, you could try turning the power valve in a bit (I find 1/4 turns make noticeable differences) until you lose power and then wind it out a bit until you are happy.
    I have no idea how lean it needs to be to start burning valves but mine is fine so far.
    Also be very careful about turning the valve out as there is nothing to stop it coming all the way out and turning it into a flame thrower. I wound mine all the way out with the engine off so I new how far would be too far.
    Jun 2008
    Warrawagine
    Quote Originally Posted by Utemad View Post
    every one talks about been lean in fuel mixture and its true about valves mainly in older motor engines. But if you are to rich and running a catilic/convertor in your exhaust system you'll turn it into exhaust brake as the honey comb will burn/melt :mad. Not good if you are miles in the scub with a fully welded exhaust system
    St Helena,Melbourne
    4.28 MB
    Duane
    When i did my first conversion, my BIL told me to do it this way and adjust the mixture till it pops then wind it back a bit, i never bothere to get tuned by analyser as it ran fine and got the average mileage i was expecting. If you fit an O2 sensor you can get a kit from Jaycar that reads the mixture and will give you a reading so you can adjust correctly.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Quote Originally Posted by NOFUSS View Post
    this is why i would not try to set the mixtures without an exhaust analyser.
    air leaks on inlet manifold can also be problems etc
    we run a fleet of vans on lpg,once set they generally go at least 120k to 150k without having to be touched.
    ummm.....make sure you have put in a new air cleaner before setting mixtures or you will have trouble when you change it later.
    also do a search on this forum as there is heaps of info on lpg around
    good luck
    saw a late model pajero with burnt valves not long ago...lpg fitted when new,so late model cars can also have problems if lpg is not set up properly
    St Helena,Melbourne
    4.28 MB
    good luck
    Last i heard Mitsubishi didnt recommmend lpg for their engines although you see a few Paj's converted now days.
    1974 VW Kombi bus
