Results 1 to 10 of 17
Thread: Biodiesel and engine lubrication.....
    NSW far north coast
    Here are some excellent articles published by Chevron on the impact of bio-diesel and its effect on engine lubricants.
    http://www.lubricantsuniversity.com/images/stories/011082%20MGW%20Biodiesel%20Magazine%2002%20(screen ).pdf
    http://www.lubricantsuniversity.com/images/stories/011099%20MGW%20Biodiesel%20Magazine%20Part%202%20( screen).pdf
    Excellent reading for those considering the bio-diesel route and its impact on engine wear and life.
    Here's a small extract form the conclusion of paper two...
    "From a lubrication
    standpoint, biodiesel’s properties render
    it more likely to enter and remain in
    the crankcase causing dilution of the
    lubricating oil. The oxidation of biodiesel
    in crankcase oil creates increased deposits
    and lead corrosion. Equipment operators
    are encouraged to conduct used oil
    analysis as well as reduce drain intervals
    to compensate for the increased severity
    due to biodiesel use. In addition, the
    appropriate use of performance additives
    in conjunction with engine oil formulating
    technologies can be used to offset some of
    the impact of biodiesel use.
    Despite these issues, biodiesel is now the
    fastest growing alternative fuel in the U.S.,
    with production soaring from 25 million
    gallons in 2004 to 250 million gallons (approximately 6 million barrels) in 2006."
    FWIW, I currently have fuel dilution issues of under 1% with conventional diesel.
    This is less than most labs can measure, (most don't flag fuel until it reaches 2-5%) and in my 300Tdi it is creating a situation that will shorten engine life, despite using 'premium' lubes.
    Singapore via Melbourne
    very interesting, but as always there is a fair element of vested interest in there...
    The part I can't get my head around is how some motor companies can approve B100 for most/all motors, others are so conservative to only approve some motors for B5! It does my head in because there is hardly any info on how these decisions are reached by the industry or specific company in question... we hear lots about "higher pressure injectors don't like Bio", some info about low pressure injectors coping better etc etc...
    what we need is an oil company to bring out bio-diesel specific motor oils with the proper blend of oxidation inhibitors added for the given Bio blend (e.g. B5-20, B20-50, B50-80, B80-100). this solves all the "problems" from an oil perspective, but unfortunately doesn't change the injector/injector pump life cycle question...
    99.87 MB
    On the flip side, what I have read is that bio has significantly better lubricity properties than diesel, especially low-sulpher.
    Slunnie
    sorry but Im going to call that slightly missleading, and considering its been published on the dollar of 3 major oil companies Im not surprised...
    there are some facts that are slightly mis-represented and unless you carefully read the whole thing you'll miss the disclaimers....
    one example is a section that mentions along the lines that biodiesel will cause additional engine wear, and then under it is a photo of the crank end of a block with a rod (presumabley attched to the piston still in the bore) and a hand with some crud held as proof, under that is a statement that without changes in the maintenance schedule and the lubricants engine damage may occour. Call me pedantic but if I put 5-15 wt high altitude winter grade oil in a diesel engine operated it at the heights of the blue mountains in winter then drove it to darwin and worked it during the wet season without changing my maintenance schedule and lubricants I'd get the same damage.
    there are however some points that are obscurely mentioned but not signifiacantly highlighted namely the quality of the bio that you use makes the most difference and there is very little mentioned about the generational differences in metalurgy and injection techniques/pressures that will change the way that using bio will effect the wear rates of your engine.
    NSW far north coast
    as bio is an ester it does have better lubricity, but that only helps on the pump/injector side.
    What they are talking about in these article is what happens when the bio mixes with a conventionally additised oil in the crankcase, and the resultant oxidative stress incurred.
    NSW far north coast
    <snip>
    They used industry standard tests like the Mack EO-O and T12, Cummins ISB and Volswagen TDI tests to evaluate the effects.
    The bottom line is that regardless of the engines metalurgy and injection type, the oxidative stress on the oil induced by fuel dilution is the same, regardless.
    NSW far north coast
    The other thing that I haven't mentioned is that the new ULSD fuels are showing to be pretty hard on engine oils too, according to the people I talk and listen too.
    Oils that worked extremely effectively 3 or five years ago are being pushed to the limit and then some by the additives now in use when the fuel gets into the crankcase.
    mcrover Guest
    Storm in a tea cup......
    NSW far north coast
    Quote Originally Posted by EchiDna View Post
    I'm betting the additive suppliers like Lubrizol are already formulating or have available additive packages to combat this.
    The fellow that does my UOA interpreting (http://www.dysonanalysis.com/) has put me onto a HOBS ester based lube that has an amazing add package that would probably work really well with bio diesel, as some of their lubes have shown excellent results in petrol fuel dilution monsters like the new DI Audi/VW's. None of the boutique syn oils, let alone the conventional synthetic VW approved oils can last a normal oil change in some of these DI engines.
    Chevron?
    Bear in mind that I'm one of the most cynical people you'll ever talk to, and I rarely like anything...
    Chevron =
    Rant over
