Results 1 to 10 of 14
Thread: What's the blackbox under drivers seat ??
    landyprincess Guest
    Question What's the blackbox under drivers seat ??
    Hi All,
    I have a black rectangular box underneath the drivers seat which I am guessing has something to do with diagnostics / settings for the engine and what ever else etc...
    Now that you have collected yourselves up off the floor from laughing too hard about my silly question....
    I couldn't find anywhere on the site (maybe I was looking in the wrong places - might even be secret mens business!!) any info on what or how one gets the info out of that 'blackbox'. Is it even called that *lol*. I'm assuming it's an additional diagnostic unit of sorts that is connected to it then a laptop and perhaps some software on the laptop??
    What type of equipment gets hooked up to it?
    What equipment do others use?
    I read in an earlier post about a nano*something or rovercom... however... are they what the majority of folk use?
    What's suitable for a Petrol V8 D2. What's a good brand / model. What setup on the laptop are folk running etc?? What costs did it set you back?
    I figure I won't be getting rid of the D2 anytime so may as well get to know the ins and outs of it and talk the same lingo as per a mechanic (or atleast try and understand what one is on about!! + it interests me to know what what with the addition to the family!
    Thanks for your help...
    Lp
    Tamborine Mountain
    Only black box under my seat is the CD stacker
    Perth, WA
    It's been a while since I had my D2, but all I remember under the seat was the CD autochanger. Mine was a TD5, so I spose the V8's could do it differently....
    To get info out of them (If you're just after error codes) you can get an ODBII reader and plug it into the diag socket. The Nanocom does this, and I think there's just been a group buy.
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    Tamborine Mountain
    The diagnostics have only been plugged in under the driver side dash on mine, so Ive seen .
    The box under your seat could be one of a few things...
    Engine ECU (electronic control unit)
    an aftermarket security unit
    the brain for the auto
    the BEM (body electrical module)
    part of the entertainment system
    the EAS controller if its fitted
    something some smart ass engineer chucked in just so i could break down or leak oil and cost money to fix.
    as for the electronic diagnosis of the thing, as a mechanic, trust me unless your serious about doing your own repair work or having the kit so another mechanic can use it if (s)he needs it dont worry about it. Odds are if you post up your location someone will be close enough and have what you need to help out when you need it. Theres other more important tricks and bodgies you should be spending your time learning as a new landrover owner rather than the diagnostics of something thats generally pretty reliable anyway.
    What to do about the 3 amigos, how to do the CTRL-ALT-delete reset if you need to get it started after youve secured it and taken the key fob for a swim and how to jam a pretzled landrover wheel brace up a tyre monkeys rectum sans lube after you find out you cant undo the wheel nuts cause hes tightend them up to 300,000 rattle pascals (280,000 dugga meters) with a 3/4 inch rattle gun thats usually used to do up the wheel nuts on a Haul pack. once you have these skills nutted you can start worrying about the big stuff like how to educate some dumb ass drive way attendant (assuming you cans still find one) that your landrover is petrol and not diesel and when youve got that sorted little things like onboard diagnostics can be dealt with.
    as for a laptop for navigation, reversing cams and entertainement thats a whole different kettle of fish but should be asked in the IT/entertainment sections.
    cheers.
    Oh yeah Welcom to AULRO too.
    Quote Originally Posted by Baffle View Post
    Yours must be a manual transmission, on the auto's the black box under the drivers seat is the automatic transmission ECU.
    Southern Adelaide
    my auto d2 td5 has the stacker under the drivers seat. its inside a little compartment, where the lid flips open to expose it.
    Mar 2007
    South Arm, Tasmania
    Yep - mine also had a black LR CD stacker under the drivers seat. Has since been replaced with a grey Sony unit - there's nothing else under there.
    Mine is also a manual TD5.
    Cheers .........
    BMKAL
    Quote Originally Posted by simonr23 View Post
    You'll find a black box is under the seat (look from the rear under the seat) I have seen the LR DVD player there as well. Lot under the seats on a D2
    RonMcGr Guest
    That box holds 10 CD's
