Results 1 to 10 of 16
Thread: more axle questions
    May 2008
    Greenbank Qld
    Smile more axle questions
    thanks to the guys who have offered me the salisbury diffs. BUT do i need a pair of them are the ratios the same or will salisbury rear and rover front be ok. I am seriously considering engineering something myself, after i have finished doing repair kits for door-tops and bulkheads. When I have these kits ready I'll post it up. they will be cheap. Lets keep more of them on the road.
    East-South-East Girt-By-Sea
    1.20 MB
    The Series Land Rovers built between 1949 and up to (but not including) the Stage 1 all had 4.7:1 diffs and most of them had Rover front diffs including those with Salisbury rear.
    The Salisbury rear diff from the SIII bolts exactly where your original Rover rear diff sits now using the same "U" bolts, shock absorbers and springs etc. There is no engineering needed.
    Stage 1 SIII (V8 and Isuzu), County and many Defenders had Salisbury rear diffs but they were 3.54:1 and not compatible with standard Series diffs.
    Hope this helps.
    Diana
    the sals ratio will be the same as the rover.
    GSKeeper Guest
    The one engineering task that will need to be done to fit a Salisbury diff into a S2A the length of the tailshaft.... it needs to be shorter for a Salisbury than for a Rover tailshaft. This also changes the angle of the tail shaft but only slightly
    PS Has anyone tried fitting a Salisbury diff in the front end???
    Central Queensland
    theyre as rare as rocking horse ****, but there are a few salisbury front diffs out there
    WA
    Quote Originally Posted by GSKeeper View Post
    Just use the tailshaft from the donor vehicle (or the longer section/tube).
    Front Salisburies were fitted to:
    S111 One-ton models
    Armored SIII models
    Armored 110 models
    FC101s
    They are hard to find. Easier to make one yourself.
    1.20 MB
    ... PS Has anyone tried fitting a Salisbury diff in the front end???
    • For a short period at the begining of the Series III 1 ton (not sold in Australia) they had Salisbury front ends with the swivel integral with the axle housing.
    • Suffix E Series IIB Forward Controls had Salisbury front diffs, but these were mostly the ones assembled in South Africa for the SA military.
    • Land Rover 101" forward controls all have Salisbury front ends with integral swivels on the axle housing.
    • The only other ones with Salisbury fronts are the Perenties.
    It would be possible to build one up yourself using Stage 1 swivels and CV's than have someone like Hi-Tough Engineering to make up some special axle halfshafts for you. Once again the problem will be the shorter length of the prop shaft and the resulting angle of the spicer joints, making it only viable in the 6 cyl chassis vehicles.
    Diana
    P.S. Didn't know about the armoured ones having them. thanks IsuzuRover
    Yinnar South, Vic
    Pretty sure they came with a 4.7:1 4 pinion rover diff
    WA
    Diana
    No worries.
    I have never seen a perentie with a salisbury. The 6x6 models have a cast diff housing (instead of pressed/tube) which weighs a ton, but still runs a rover diff (albeit a specially made 4.7 reverse-cut crownwheel and pinion that can only be fitted to 3.54 centres).
    I have seen one-ten front axles with bolt-on swivels.
    You are right that we didn't get any one-tons - the only front sals's that made it here were in FC101s AFAIK.
    1.20 MB
    No worries.
    You could well be correct about the Perenties, I have never seen one on a Perentie myself, however about 2 year ago there was a complete Salisbury front end on Ebay (vendor in South Australia) advertised as being off a Perentie.
    Perhaps it was off a pre-production Perentie or as you say one of the armoured 110s etc. What do the SAS LRPVs have?
    At one stage Allspares in Sydney, had a Salisbury front housing and there have been a number of private imports, most noticably one of the Series III 1 Ton prototypes that arrived in Sydney during 1974. I last saw that vehicle in Alice Springs in 1981 (sadly missing it's Scottorn Bushmaster powered trailer but not the drive coupling for the trailer).
    Diana
