Results 1 to 2 of 2
Thread: TD5 Clutch Master Cylinder
    DougLD Guest
    Hi All
    Need to replace the clutch master cylinder in our 02-03 Disco TD5 7 the cost has frightened me a little does anyone know where i can pick up a aftermarket one while i am at it i think will replace the slave cylinder. I thought nearly $400. 00 a bit expensive.
    Doug
    Mar 2007
    South Arm, Tasmania
    You're right that nearly $400 is a bit expensive.
    I recently had both the master and slave replaced in mine - including installation and bleeding (they can be an absolute mongrel to bleed) at a LR service workshop in Perth (not a dealer) and the whole job came to less than $400
    I'd be looking around.
    Cheers .........
    BMKAL
