Results 1 to 10 of 13
Thread: Power chip for a disco2 v8!!
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Hi there
    A mate of mine is after more power out of his 4ltr v8 and has decided to chip it!
    He tried a UK mob but they hadn't made one for his bosch system yet.
    So i was wondering who sells them in AUS??
    Maybe bruce davis
    If anyone knows where to get one please let me know!
    CHEERS TIM.
    Bruce Davis Performance Landys at Annangrove do one.
    Bruce wants to chip my P38A.
    Melbourne, Australia
    What sort of performance gains will this chip offer?
    I can understand how a chip would work with a TD motor, but on a naturally aspirated motor, it probably can lean out the mixtures or enrichen the mix, but will this cause problems for the motor long term?
    Or will it be just more fuel = more power = more fun but at even worse fuel economy.
    Oct 2007
    Thanks Ron i thought bruce would have to do one.
    CHEERS TIM.
    Daisy Hill Queensland
    Isn't your motor the early type of injection, D2 is different to 1995 4.6 P38A
    :TakeABow:LAND ROVER
    Don't Follow Me, I'm in a "Land Rover", You WON'T make it.
    aut viam inveniam aut faciam
    May 2008
    Sydney, NSW
    I had my 2003 4.0 chipped yesterday with a Haltech unit from Graeme Cooper in St.Peters. I obviously have not had time to detrmine my fuel consumption but when dynoed I recieved a 30Kw and about 30-40Nm power increases. This sort of increase is certainly noticable on the road and the low down torque (idle-1700rpm) is greatly increased.
    Glenn.
    4X4V8 Guest
    When you say chipped, what exactly is that? An ECU replacement chip, a reflash or a whole new engine management system?
    Just wondering cos I thought Haltech only made complete programmable fuel/ignition management systems, not just a chip.
    Is yours the high compression 4.0?
    Those are impressive gains. Wonder what fuel consumption improvements you'd have.
    Bruce Davis was talking 10 per cent gains in perf/econ for around $500 for a new ECU chip. What did your set-up cost, if I may ask?
    May 2008
    Sydney, NSW
    Hi 4x4V8,
    Sorry, I wasn't too informative in my comments. The Haltech unit is a complete Management system ($1200 Incl. install, configs and Dyno)that plugs into the existing ECU, which also means that when I sell the vehicle I can just unplug the unit and add re-install it into my next vehicle. I have a High compresssion 4.0 and as I commented before the low down torque is a complete transformation. We did a Dyno last week on the stock engine which produced 68Kw's at the rear wheels which I am told by Graeme Cooper was a little on the low side. I checked engine compression and all clearances which were all well within recommended specifications (engine has done 58000Klm's).
    I have been told that the ECU upgrade that is supplied by Bruce Davis is just re-mapped chip and is not configured to your indiviual engine tolerances so I think the extra money is worth it.
    I will let you know the fuel consumption figure at a later date.
    Glenn
    P.S. - This is my first ever LR which I have owned for just over 2 months. It is a fantastic vehicle but I have been getting around 22-25Lt/100 in Sydney suburban driving which has blown me away as I expected better. I have asked a few LR mechanics and they all say that this is normal. Any opinions on this subject would be great feedback.
    Mar 2007
    Perth WA
    Haltech do make plug in interceptors as well as full stand alone ecu's. IMHO you can go past a stand alone system, but a inceptor has the benefits of being cheaper to fit and easier to transfer to a new vehicle.
    4X4V8 Guest
    Yes, I am afraid that this is normal. The stop-start and idling in short bursts kills 'em. The D2 V8 can be amazingly fuel efficient in the right circumstances for such an old engine in such a brick of a body, but also the complete opposite.
    Have a search for fuel consumption, there are quite a few threads about it.
    I am onto my second 1999 D2 V8, the first an auto, this a manual. I did a worst of around 22-24L/100km in peak-hour to the City and back from Ashfield in the auto.
    Now in the manual, still in the mid-20s with short urban runs of <10km. Was up to 26L/100km with a faulty MAF sensor and poorly insulated ign leads.
    Drive out on the open road and consumption plummets. Just under 13.0L/100km was my best out of the auto on the highway, mid-13s easy to achieve. haven't driven the manual for a long enough distance on the open road to know what it averages.
    Now get this: I have just driven from Burwood to Northmead using M4/James Ruse Drive/Windsor Rd. Have just installed a new sports muffler (and it sound bloody great, too, I might add) so don't know how much the slightly less exhaust back pressure might be helping, but on the way there I was foot down and enjoying the V8 sound (did I mention how great it sounds?) Did 14.2L/100km for the trip, on my ScanGauge. Leaving Northmead and driving very gently, but still keeping up with traffic, I saw 11.7L/100km at the end of the M4. Once I got into congested roads around Burwood Road, consumption rose again and settled into the 14s.
    Trip computers shouldn't be taken for granted, esp on such a short distance, but if calibrated properly can prove quite accurate. I need to ensure mine ScanGauge is correctly calibrated for the D2 (have been using it in another car recently) but given it doesn't flatter me with good consumption on the school run (25L/100km), I don't see any reason for to today.
    Keep us posted with your impressions on the Haltech, economy etc. I didn't realise it was a plug and play loom - I vaguely remember Graeme mentioning it but I thought it was a complete re-wire job. That it is a plug-and-play (with tuning I know, but not invasive to OE wiring) is great.
