Results 1 to 10 of 17
Thread: SIIA are frustrating things...
    Keilor East, Victoria
    Well, mine is anyway....
    I ordered a new radiator hose, what sort i am asked, straight or angle, hmm angle...
    get the hose set, doesn't fit, have a good look, custom fittings in non factory spots, looks like i have to go custom hose shopping again on saturday unless slunnie can remember what hose to use on the bottom of the raditor i got ?? otherwise i might just crack the sads and get the original radiator soldered up and fixed.
    fitted the fuel filler hose replacement, man that was a struggle.
    re fitted the fan belt (easiest job of the night)
    fitted new clutch slave cylinder, and hose... pump up, bleed (like the idea of doing the bleed whilst pumping the pedal... but, it won't engage the clutch when i depress the pedal to the floor now, grinding whilst hunting for gears it the clutch comes to rest, i can ram the piston back in the slave cylinder about 1 1/2 inches. it only rotates the clutch arm about 10 degrees in total
    i did also manage to fix the oil leak from the fuel pump though
    Boonah, QLD
    Join the club mate - i'm doing radiator hoses and flush atm... the old water in my radiator looked like coffee!!! Not to mention the frozed hose clips that had to be surgically removed with a hack saw. Then there was the whole removing the seatbox and tub saga - who the hell designed these things??? they should be shot!!! i don't even know how they put them together - there are some bolts in the most aquard spots to get spanners to made all the more worse by 38 years of rust!!!!
    ARRGGG GRRRRR!!!!!!!
    Felt good to ge that out lol, needed a winge
    Quote Originally Posted by Newbs-IIA View Post
    i purchased many new bolts when i started this project, as all the bolts i undid were rust piece of @#$ and most sheered.
    i might get the blow torch tonight and have a go at fixing the original radiator.
    Steve
    Cessnock NSW
    G'day All, I see your biggest problem is that you haven't been around Land Rovers for very long or am I incorrect, another problem is the parts suppliers some of those people don't have a bloody clue.
    As for design, it is the simplest design in the world, I would sooner undo a heap of bolts and lift the G/box out the top rather than struggle with some Jap crap underneath, you need to curse the previous owners who have neglected the vehicle.
    Nuts and bolts will oxidise with Alloy when wet over a long period of time, but with some patience most bolts etc can be unscrewed and reclaimed, if US replace with new ones and apply a small amount of never seize to the threads, I generally paint all nuts and bolts washers etc before my rebuilds go back together this helps minimise problems with oxidisation down the track, and yes it does consume a large protion of your day just doing that, anyway cheers Dennis
    Boonah, QLD
    Yea i'm new to Rovers
    I sheared a fair few of mine and pretty much all of the bolts holding the body onto my chassi will be replaced as they are not worth putting back in. The worst part was that most of the captive nuts that hold the front of the tub to the chassi broke free of the piece of steel they were welded too which meant i had to drop the fuel tanks to acesss them with a good socket and torque them off with brute force... I haven't got the luxuries of a gas-axe
    I'm growing to like my old battle truck though
    ianyates Guest
    Time and WD-40 are your best friends. Apply copious amounts of WD-40 on day one, to every bolt you think you might need to move. Then go and do something else until day two......
    olmate Guest
    What can I say - the joys of.... Once you get thru the thing a couple of times all of these problems go away as you replace / repair bolts as needed. Dennis and Ian have said it well. It is very basic and one big Mechano Set
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by ianyates View Post
    Ian is correct. The original bolts on Land Rover are zinc plated by a sherridising process which is a very resisiliant process. The big problem is the crud and corrosion on the exposed portion of the bolt and where non standard bolts have been replaced or damaged bolts re-used.
    Buy yourself some little wire brushes and scrub off the exposed threads first, then the WD40 or similar and then tackle another job or have lunch etc. If you still have trouble work the crud loos by alternate tightening and loosening a little bit at a time. If the thread gets tight, back off again and apply some more WD, then have a cuppa.
    It is a good practice to have a little pot of Loktite Neverseize with you when you replace bolts. A little dab on the thread and you or the next person who undoes the bolt will have an easy job. (Particularly on wheel nuts.)
    Diana
    well, i have probably bought 100 1/4" and 5/16" anda hand full of 3/8" UNF bolts (zinc) and mixed normal and nyloc nuts. Just bought a bulk bucket of grade 4&5 Zinc UNF bolts from 1/4" x 3/4" - 5/8" x 4" so i should have a new bolt for nearly every single application.
    neversieze... hmm... i keep meaning to buy some. must grab some.
    found a cheap supply of brake fittings in the UK, better than the $6 each form ABS here! i can get 10 for $6 from the UK...
    As Diana says.
    Series 1 and probably S2 had sherardised bolts and nuts and washers, as far as I know now unavailable - although it is possible to do these yourself if yoou are keen enough! Later ones had galvanised, and these are available, probably special order and by the box (I don't think you can get nyloc nuts galvanised).
    Zinc plated fasteners are only slightly better than black steel in this application - stick out for galvanised. If you live right on the coast, there may be a case for using stainless, but you should ensure it is electrically insulated from the aluminium using neoprene or nylon washers and short tubes where they go through the panels.
    If you use any of various antiseize compounds they will ensure you can undo the bolts next time.
    Several years ago I completely disassembled the body of my 2a to repaint it, and probably twisted off half the bolts. A very few had to be ground off or drilled out. I used some new fasteners, but mostly were reused either from it or another one I stripped a few years earlier. As they were reassembled using antiseize, the ones I have had to disassemble since have proved to be easy.
