Results 1 to 2 of 2
Thread: 300Tdi Overhaul manual, and clutch slave tool
    NSW , Pennant Hills
    May 2003
    On The Road
    This from "acer3505"
    Clutch slave cyl pushrod clip insertion tool
    My first post ... hope this helps someone.
    I recently replaced the clutch slave cylinder on my 300 tDi 130 Defender. Of course the pushrod retaining clip came loose in the process.
    After a bit internet searching I got the general idea how it might be replaced.
    I used a piece of 10mm dowel and center drilled it so the pushrod was a sliding fit - PVC or stiff plastic tubing would also work I'm sure. At one end I slit the dowel at 4 sites 90ยบ apart.
    A couple of daubs of Correct-it fluid on the back of the clip made alignment easier to spot inside the housing. My wife wound and tied off 3 wraps of cotton around the prongs when I slightly compressed them, then a piece of fishing line was tied around one one of the three wraps.
    Insert rod into clip then into dowel. At the slit end wrap a small cable tie around and tighten such that the cable tie lock is opposite the clip prongs and the rod /clip is locked to the dowel.
    Insert device into slave cyl hole align via cable tie, hold your tongue correctly , swear a bit and then press it home. Once you are sure (I checked with a small mirror), yank the fishing line whilst pressing against the rod end , off comes the cotton and hopefully the clip stays there. Nip off cable tie and slide off dowel.The attached photo shows the general idea .
