I can answer some of these.
2. brown!
3. about correct. The td5 will go to a fraction over 5000 i think
 Master
						Supporter
						Master
						Supporter Just purchased TD5
 Just purchased TD5
		Hi All, I have just purchased a defender 130 td5. Looked at tdIs and thought about the 4db1t option but his was a bargain so could not go past it. But i have some questions.......
#1 It has oil around the turbo outlet that goes to the intercooler. The oil is sitting on the hose only, around the turbo out let.
#2 The coolant resivoir is a brown color and i cant see throught it to check the level. What color are they originally?
#3 It has had a tacho fitted and seems to rev very hard @110 over 3000rpm is this where they usually sit? And if so, it has heaps of power further down it the rev range so would it be better to lower the rpm @ 110?
#4 The turbo whistles very loudly when it is working is this normal?? It has 3 inch exhaust and has been chipped. Sounds like a truck i love it!!!
Thanks guys
PS I drove the vehicle from melb to Mildura yesterday and it was the most enjoyable trips i have ever had!!
2. brown!
3. Sounds about right. I think you'll find they're electronically governed to 4500 RPM.
Cheers and congrats on your purchase.
Can't answere the revs as my auto revs lower than a manual. Wistling is probably normal but check the exhast manafold incase of a broken stud.
as edd said check your exhaust manifold#4 The turbo whistles very loudly when it is working is this normal?? It has 3 inch exhaust and has been chipped. Sounds like a truck i love it!!!
but if its chipped i'd be guessing its a warped manifold
thats where you whistle will be coming from ...........
130's rule
 Master
						Supporter
						Master
						Supporter Master
						Supporter
						Master
						SupporterSorry on second thought i am thinking of an exhaust manifold...whoops...
But seriously is there a way of telling other han pulling it off???
try tightening it first it might just be loose
as for the oil coming out the bottom of the turbo
its possible that the owner has tried to fix the warped manifold and hasn't replaced to little pipe properly that comes out the bottom of the turbo
cant remember completely but i think theres a flange that it needs to be seated in..........
130's rule
