Results 1 to 3 of 3
Thread: D2 TD5 Fuel pipe - Part Number?
    Bunbury, WA
    Question D2 TD5 Fuel pipe - Part Number?
    I am hoping that someone here can provide me with the LR part number for the green coded plastic fuel pipe that runs from the fuel pump to a joiner near the fuel filter (See photo). My nearest dealer is 250km away and I have had no luck describing the pipe to them over the phone.
    I believe this is same pipe that was replaced via a recall notice. Mine had this done, which subsequently rubbed through (replaced under extended warranty), which also rubbed through (again replaced under warranty). I need a new one again which I will be replacing myself to make sure it is done RIGHT this time.
    Hope someone can help...
    Douglas Park, NSW
    The recall number is D169 so the dealer can get the part number from that. It's a YNI..... number
    It's quite common for the fitter to shortcut the repair by not removing the tank. As you now know, the problem returns when it's done that way.
    It doesn't look like it's listed separately in MicroCat - the four pipes are listed as an assembly.
