From previous threads: no relays are fitted.
Hi all
simple one for those in the know
are the headlights on a D2 fed via a relay or direct through switch
would like to upgrade wattage of globes but not fry the existing switchgear ??
Nobby
I've been running 90/100 since about 2002 and there have been no problems with the switch gear. Where they do eventually fail is at the plug that goes into the back of the globe - they slowly melt and increase resistance until they fail. I now run a Traxide headlight box and loom with relays etc in it and so far so good.
Slunnie
Just remember if its a post 03 D2 with the polycarb lights, DON'T put higher wattage bulbs in or you'll damage the lenses.
The D2 isn't affected by them... except the glass will crack if you do night drives in water.![]()
Slunnie
No its a 01D2 with conventional lights
Slunnie thanks, but excuse my ignorance
what is a traxide Headlight box??
Nobby
Its one of these
HL_info
It's Drivesafes business on here and been a great product so far.
Slunnie
