Thread: NanocomFirmwareLoader.exe
    Manly QLD
    Question NanocomFirmwareLoader.exe
    Hi
    I did a search for this and came up empty so apologies if this has been covered.
    I have firmware 2.01 and believe I should upgrade to 2.01p. All the doco mentions use of the application NanocomFirmwareLoader.exewhere is it? I’ve searched my PC (after install), the supplied CD and finally the Nanocom website – nothing….
    I’m sure I’m missing something…..
    Padstow NSW
    all in this thread
    http://www.aulro.com/afvb/electronic...l-nanocom.html
    remove old software, reload 2.02 update.
    cheers phil
    Manly QLD
    Quote Originally Posted by discowhite View Post
    im having trouble with the patch also. this is the reply from nanocom. i still havnt got around to installing the patch.
    this is also in the nanocom faq section.
    To load the firmware upgrade that you can find in the restricted area of this web site:
    • First you have to disable the INSTRUMENT option if it is active. To disable this option you have to give power to the Nanocom keeping pressed key 1 (the first on the left) until the display shows the words "NANOCOM rev X.XX" like the normal startup. Now enter the function STARTUP SETTING of the NANOCOM SETUP menu and select the item NORMAL instead of INSTRUMENT
    • Now press OK and ESC until the Nanocom turns off, or cut the power supply
    • Connect the Nanocom to the PC through the USB or RS232 port
    • Turn on the Nanocom without pressing any key, the display must show the words "push a key or connect me" and the LED must be on with RED light.
    • Launch the application NanocomFirmwareLoaderX.XX.exe
    • Select the COM port number used by the Nanocom (required also for the Nanocom with USB because the USB device is seen by the applications as an emulated COM port )
    • Click the button "Download" and wait for the end of the process.
    • The firmware is correctly stored when the "Firmware download done succesfully" message box appears
    • Click Ok to close the application
    cheers phil
    Thanks Phill
    However that email basically says “New firmware ready to go” – doesn’t answers my question. I have uninstalled the old PC software - installed 2.02; I now want to install the new firmware on the box but can’t find the exe mentioned in the following step.
    Obviously I’m missing something, where do I find this executable?
    Ermington, NSW, Au
    Quote Originally Posted by harlie View Post
    Thanks Phill
    There are two download locations on the nanocom website.
    From the Nanocom website toolbar they are called-
    >Downloads
    >Restricted area
    The firmware is found in the restricted area. You need to register on the site and receive a password. Once you've got that you can log in and download a ZIP file (NanocomFirmware2_01p.zip) containing the firmware loader.
    Extracte the ZIP file and you will get NanocomFirmware2.01p.exe
    Hope that helps.
    2012 110 Defender
    Manly QLD
    Thumbs up
    Beauty thanks guys, now I'm on my way.
    It’s not exactly “follow it to the letter” stuff. Have to run NanocomFirmware2.01p.exe which is the installer and contains the unit's OS – mmm bit different.
    I was looking for an extra deploy tool (of sorts) called NanocomFirmwareloader2.01p.exe – that’s where I was mixed up – read the instructions too many times..
