I personally wouldn't use it as it's a welded recovery point.
I prefer the one piece type. As you have found out, the off the shelf items are too short so you (and I) need to get one specially made.
RANGE ROVER - 4WD 4 x 4 - RECOVERY POINT HITCH - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 28-Jul-08 17:40:33 AEST)
I've been looking for a recovery hitch to fit my ARB rear step, but the off-the-shelf items at ARB/TJM are too short.
What are your thoughts on this item?
Any other suggestions for a rear recovery point?
It wouldn't bother me too much as long as who ever made it could weld. My RUD lifting eyes I have for recovery on the back of my 90 are welded on to the chassis.
If you could tell me the sizes and materials, I could tell you how strong it is, by running it through my FEA software.
Rgds
Peter
I've had one of these for about a year or so, snatched my mates GQ out on numberous occasions and haven;t had a problem, only thing is now the paints a little chipped off where the shackle has been rubbing. Before that i was just poking the strap down the hole and using the pin, definately a pain as the pin is right under and normally covered in mud!!
1986 Range Rover Hiline
2004 D2 TD5
I've also got one, seems pretty well made to me. Solid too.
I haven't used it yet though, but for the price it seems like good value.
Trav
I certainly wouldn't be put off by the fact that something is welded- like Peter says the question is whether it is welded right. What sort of accountability is there for someone selling something on eBay with an alleged load rating? Was it welded over a dung fire in the Mekong Delta and the number of pigs in the village stamped on as a load rating? Or was the wall thickness of the SHS and the cross-sectional area of weld specified by engineering calculations and then carried out by a qualified tradesman? How do you know??
It'd be interesting to see if there was any elongation in the holes that the receiever pin goes through after some heavy snatching.
Slunnie
If the weld is done correctly theres nothing wrong with it, the weld area
is stronger than the parent metal
but why buy one when you can make your own and get that warm fuzzey feeling
T
