Results 1 to 2 of 2
Thread: Where is the best place to get......
    West Victoria
    standard body mounts for an 89 model rangie?
    I am turning my bush truck back into a road/everyday driver and going 2 door for the bush truck, so I want to remove the home made body lift kit and drop the body back down on the standard mounts.
    I'm after a cheap set, if anyone has removed them to put in a lift kit and they are still in good nick, let me know.
    Neale
    Rangier Rover Guest
    Quote Originally Posted by Corgie Carrier View Post
    Neale
    Not worth the hasle. Seat belt mounts, Steering shaft,Rad,etc. However mounts and bolts will swap from your 2 door. If you don't need it sell the 2 Door, Keep the 4 Door as a basher and buy a rice burner for everyday driver might be an option.
