Results 1 to 10 of 36
Thread: 200tdi or 3.9 Isuzu......
    Dayboro, Qld
    I've been reading your threads for a while now, and am curious to know the main attraction of the Isuzu over the standard 200 tdi.
    Is it the power ??? Reliability ??? Low maintenance ??? Can you please explain what it is or shall I just carry on and purchase the one I've got in mind and find out by myself
    On a serious note what is the number one fault to look out for ??
    Singapore via Melbourne
    compared to a 200TDI?
    wear in the drive train downstream from the motor...
    the 4BD1 has torque to spare, has more power, it's bullet proof, similar efficiency and lasts longer!
    on the downside it rattles more and is noisier too!
    Apr 2007
    Clifton Springs, Vic.
    If you owned a 4BD1 you wouldn't need to ask
    The advantages of the Isuzu compared to the 200Tdi are mainly durability and reliability, with the addition of better low down torque and driveability. (not that the 200Tdi is bad on any of these, although the Isuzu is likely to have twice the life).
    The down side of the Isuzu is the vibration and greater weight on the front wheels, which can lead to wear on some front end components and on the gearbox and transfer case.
    WA
    That pretty much covers it.
    On the matter of gearboxes...
    The LT95 4-speed has no problems behind an ISUZU. IME the LT85 5 speed last as well behind the isuzu than the LT77s does behind the 200tdi.
    Quite a few people have fitted late model R380s behind 3.9s and they are working well. A couple of people on here have ISUZU boxes, but this isn't the world's easiest conversion, as the box is cable-shift, and you need a serious spacer between the box and the t-case case.
    But the bottom line is - drive one and you will FEEL the difference Both in the seat of your pants AND in your teeth
    EDIT - p.s. - whereabouts in Dayboro are you? Know anyone with the surname Chambers?
    Dayboro, Qld
    Thanks for the advice, the one I have in mind to purchase has had lots of $$$ spent on drivetrain, axles etc. Until it's on my drive I'm keeping quiet about it though, don't want it to fall into the wrong hands although the deal is as good as done.
    isuzurover, I can't say I know anybody with that name although I might know them by sight.
    Quote Originally Posted by EchiDna View Post
    Hang on a minute, I thought Tdi's had slightly more power and torque than 4BD1's. 4BD1T's are a different story!
    when all stock the TDIs all have it over the 4bd1 in terms of max torque and max power......
    however that doesnt tell the whole story.. Its the way that the isuzu develops its torque that counts its sort of like comparing a well tuned 2.25 to an old holden 6
    sure the holden 6 has it all over the 2.25 BUT....
    well tuned and setup the 2.25 starts making usable torque at 500RPM which is conveniently 100 RPM lower than idle.
    The best Ive ever seen was a petrol 2.25 5 main that Idled at 300RPM as smooth as butter and would if let up easily on the clutch walk around at those RPMs...
    you pick the engine for what you need it to do.
    If you want to tow or go off road and you dont mind slow but Must have reliabilty you go for the suzi pushing a 95 if you want it to be faster and can deal with a degrade in low end torque and slightly more expensive maintenance and the potential for more breakdowns then you take a tdi pushing and 85 or an r380. the tdi is marginally more fuel effecient
    the TD5 bridges both these motors offering more go more torque and more fuel effeciency but you pay for it in maintenance..
    just IMHO...
    33º 29' S 150º 13'30" E
    I think there's a better supply of spare parts for an Isuzu, too. Things like cyl heads for 200tdi's are virtually impossible to find, even 2nd hand.
    Quote Originally Posted by Taz View Post
    You are right, but as Dave says - the numbers don't tell the whole story.
    To a large extent, the driveability depends on the shape of the torque curve more than the actual peak value of that curve - high peak torque is not much good if it is available only over a narrow range, and a lower peak torque may be a lot better to drive if it is less peaky. Also important is the torque available at clutch engagement rpm.
    While the Tdi is not bad in these respects, the 4BD1 is better, despite having lower torque and power. Ultimate performance of the Tdi is better however, showing up particularly in towing at highway speed - the Isuzu will slow more on hills, particularly with the four speed box, where maximum speed in third is below 100kph. Off road the better torque curve of the Isuzu completely masks the lower peak torque.
    The comparison of these two engines is a good example of the fact that just the peak power and torque figures, even together with their rpm, are not the whole story.
