Results 1 to 3 of 3
Thread: The adobe acrobat reader that is running cannot be used to view a pdf document in a w
    May 2003
    On The Road
    "The adobe acrobat reader that is running cannot be used to view a pdf document in a web browser"
    whats the go here,,?
    I have adobe reader 9
    Dalby
    Have you been using a RAVE disc?
    RAVE uses an older version (maybe version 4) so if you have RAVE open you can't open Adobe 9 or anything that needs a newer version than RAVE has.
    Sometimes even after I've closed RAVE I have problems so I open RAVE and close it using File/Close as opposed to the red X. Then all is well again.
    You don't have the browser plug in for adobe 9 by the sounds of it. I'm still running v8 so haven't tried to upgrade.
