Results 1 to 9 of 9
Thread: My attemp at Macro
    My attemp at Macro
    ok so i brought some cheap tubes and i thought i would have ago.....
    not to bad i thought, i dont have a flash so i relied on the sun being quite high.....
    now one thing i noticed was my area of focus was very small that was having pics taken in both big and small F numbers could this be because i was using a zoom lense rather than a prime lense, or is that just the down fall of taking with stacked tubes?
    and sometimes to me it appeared that it was crisp off to the side and not in the centre......
    i had to manually set aperture and i was unable to select any sort of metering system so basically it was manual set up and manual focusing does that sound right? or am i doing something wrong
    ok here are the pics
    Dalby
    No idea on the technical bits but I like the peg photo. Nice and simple with just the four colours.
    Any close up like that is going to have a very shallow focus point (whatever the technical terms are).
    300+ Guest
    Quite impressive, I must buy some tubes!
    You can deal with the depth of field problem in some cases by taking multiple exposures are different focal points. Then put them into layers in PS and delete the out of focus parts from each layer. This should leave only the in focus parts. I've never tried this, but read about it in mag.
    Requires a good tripod and a steady subject!
    Cheers, Steve
    St Helena,Melbourne
    4.28 MB
    I'm not familiar with nikons but depending on the ext. tubes you have , because the DOF is so shallow when you open the aperture up you may need to manually focus to get the effect you want or point of focus to be sharp. Which tubes did you buy ? A mate got me a 50mm F1.8 lens and at F1.8 there is an area of less than 1" that is in focus with front and behind nicely blurred .
    Although a true macro lens with 1:1 reproduction would be nice a good macro zoom can focus as close - my sigma will focus on an object touching the UV filter !
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    i had to manually focus any way.....and i must not of explained my self very well! i had to do everything manually including setting aperture shutter speed focus and had to get the exposure right by doing all of these with out the aid of the exposure bar..thats why some are a tad over and a tad under i just figered i could pull them back in the light room
    you cant auto focus with the tubes on
    (so the photo's above by the way are un touched)
    my point being when focusing i had only a very small area which would sharpen.....
    if you look at the yellow flower there is a patch in the middle that is soft yet off to the side is sharp
    its almost like my focusing point has been locked off to the left
    this was done with my tamron 2.8 which also says macro in the title.....these shots were taken between f4 and f11
    300+ Guest
    If the focus is off like that it could point to slightly non-parallel tubes. It wouldn't take much to have an effect. Or the minimal depth of field is showing a pre-existing lens fault.
    Steve
    Quote Originally Posted by 300+ View Post
    Steve
    mmmm interesting.....food for thought
    although thinking about it it didn't do it on all of them maybe it is something to do with the tubes or maybe its just me
    St Helena,Melbourne
    4.28 MB
    I understood what you meant, its only cheap tubes that dont have the electrical contacts that allow AF to function, thats what i was saying by with macro and especially using large apertures you only have a shallow depth of field so it makes focusing harder if you have a range of distances on the same object that you want sharp. More than likely it is user error and not the tubes that prevent a certain area from being in focus- have had the same problem, they look good on the camera but once on a 19" monitor they are a bit soft .
    1974 VW Kombi bus
    Fleabag Guest
    There is nothing wrong with your lens, tubes or camera: all you've done, in manually focusing, is accidentally focused on an area of the yellow flower to the left of centre. All the other shots are correctly focused in the middle.
    At the Macro level focus is very touchy.
