Results 1 to 10 of 12
Thread: Rear Tyre Mount
    Jul 2008
    Rear Tyre Mount
    Hi,
    I have just purchased some 235/85/16 tyres, one thing i totally forgot about (having previously owned a Defender) is the rear tyre mount clearance from the rear bumper, basically i can not fit the spare on...
    Does anyone have a simple workaround for this, where i can still mount the tyre on the rear, leaving the tyre in the cargo area is not really an option.
    Turn the wheel mount upside down on the rear door.
    Jul 2008
    I was never known as a lateral thinker...
    Thanks for the advice.
    I was imagining welders, grinders and a day in the shed....
    I'm assuming you have a Disco.
    You can also try (Not sure if its a D1 or a D2) undoing the bolts on the bar & dropping the rear bumper, i did this on mine & worked just.
    mcrover Guest
    I dont know why but mine just fit
    McDisco Guest
    You can also buy adaptor plates that bolt onto the carrier are set the wheel higher. Benefits are that you dont have to fiddle with the trim around the door to get at the bolts to invert the carrier, disbenefits include the tyre being higher and perhaps putting a bit more load on the door. Had mine like this for 3 years and no problems.
    Angus
    Jul 2008
    Yep, it is a D2.
    Jun 2008
    McMinns Lagoon NT
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Success WA
    Quote Originally Posted by Lightweight View Post
    Hi,
    Hi
    My 235/85 16 MT fitted on the rear carrier without even changing anything, But now I have heaps of room because Its body lifted 2 1/2
