View Poll Results: Where should we mount our second spare for the Cape Trip?
Voters
36. You may not vote on this poll
  • Buy a bigger full length roofrack?
    4 11.11%
  • Buy a secondhand bonnet and mount a spare carrier on it?
    15 41.67%
  • Mount the spare against the cargo barrier?
    3 8.33%
  • Something else - Suggestions..... anyone?
    14 38.89%
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Good spot for 2nd spare wheel on CCCCC trip?
    Treads Guest
    I'm trying to work out the best spot to carry an extra spare in/on Tulips Deefer for the Cape York trip next year.
    We have a 3/4 length (1880mm x 1330mm) alloy roofrack; however we will be sleeping in a rooftop tent for the trip (1400mm x 1200mm). Unfortunately that means we won't be able to fit a spare on the roof with the tent up there, as there is only 680mm of room left for a spare 235/85R16 that has a diameter of 806mm.
    So now the quandry, do we:
    1> Buy a full length roof rack? ($$$$$$ )
    2> Try to find a second hand bonnet and put a bonnet mount spare on just for our big trips?
    3> Mount the spare on some sort of bracket attached to the load side of the cargo barrier?
    4> Some other way?
    Thanks in advance for any help/advice/experiences
    Last edited by Treads; 14th August 2008 at 08:37 AM. Reason: Added photo of Tulip's rack :)
    From what I have been led to believe your rack (and mine) is not the ideal spot for a Roof top tent due to it sitting way up in the air and creating a lot of drag, plus most I have seen seem to be fitted to Rino rack setup.
    Personally I'm getting me bonnet reinforced and bonnet mounting my 2nd spare
    Ever thought about having it mounted in the back of the Defender? Like the original spot on the Panelvans
    Mount it directly to the roof infront of your roofrack.
    Jan 2008
    Brisvegas
    Treads,
    Don't do the bonnet thing, it cuts down your vision immensly in the tight stuff.
    Is that the rack you are attatching the tent to? How is it going to fit with the side rails?
    You might not not need to take one as there will be copius amounts of spare wheels all on the same stud pattern.
    I would suggest a new full lenght rack with a flat section at the back for the tent and luggage at the front, Or move that rack forward, and attatch the tent to roof rails behind it.
    CC
    Treads Guest
    Quote Originally Posted by dobbo View Post
    Yeah, I wondered about that too
    I thought about that, but wasn't sure if it would work in a wagon?
    Jul 2007
    Auckland, NZ
    It's the second spare right? Why not put it on the floor, up against the middle row of seats?
    Alan
    2005 Disco 2 HSE
    1983 Series III Stage 1 V8
    Torres Straits
    What a bout a pair of roof bars ?Suparax? or whatever then put spare on that...
    S
    I picked up a second spare in Derby for my daughter's Disco. As we didn't have a roof rack and as it's too damn dangerous (and difficult) for a slight girl to drop a wheel from the roof rack, I opted for strapping the spare to the cargo barrier.
    You can buy a Y-shaped tie down strap designed for strapping wheels down (to roof racks, actually).
    See Sabelt Spare Wheel Ratchet Tie-Down - $75.00 : Racer Industries, Performance Parts Retail & Wholesale
    Treads Guest
    Quote Originally Posted by disco2hse View Post
    That was kinda a sub-option 3 I'm building a long drawer for the back and I guess a spare could just be packed on top of that?
    Quote Originally Posted by Col.Coleman View Post
    Treads,
    That was definitely my last option, I've driven RFS 110 utes with bonnet spares and hated the restriction of vision, that's why we'd get a second bonnet just for big trips if we went down that road.
    We were either going to get cross bars made up to support the rack at the height of the side rails, and store light long items underneath; or have the rack altered and the rails cut off either the front or back section (dependant on which way we want the tent to fold out).
    I thought of that, but this setup needs to be good for our shakedown trips before CCCCC, and for ongoing adventures
    Quote Originally Posted by roverrescue View Post
    We thought about roof bars if we had the rack altered (after cutting off part of the side rails as above)
    Cheers for the suggestions
    Is that a TD5 sticker? Then the genuine bonnet carrier won't fit.
    I suspect corrugations will wreck the bonnet/hinges anyway. Same with sticking ot on the roof. The good thing about a roof top tent, in a funny way, is you can't overload the roof.
    Is your back seat in or out? If out, what I do is stick the 2nd spare on the inside of the cargo barrier. Secure it with those mega ton straps, then put the seat belt around that.
    If you position it with the wheel outside face toward the barrier, that leaves a useful cavity facing you, inside the straps/belt. It's ideal for hoses, shower hoses that sort of thing.
    Max P
