Results 1 to 10 of 15
Thread: Is it dead ?
    Two Rocks, Perth
    Is it dead ?
    RR Classic, 4.2l EFI. Drove fine, then last week wouldn't start. Was fine when parked at night but wouldn't start in the morning.
    Cranks over until battery is dead, no life at all. Tried several times over the last week or so.
    Checked everything I can think of. Sparks seem OK, fuel seems OK, air seems OK, new heads about 8 months ago so compression should be OK. I assume if one injector goes it still runs and the chances of 8 injectors going at the same time seems pretty remote, so I guess injectors OK.
    Is the ECU the only thing left ?
    I put new coil in and replaced a couple of cracked fuel lines, but I don't think there was anything too wrong with them, it didn't make any difference.
    Took the ECU out and took the cover off, nothing visibly wrong (burnt componets etc). Is it possible to test or bypass the ECU in some way or do I have to get another one ?
    Thankyou
    sunny Hobart
    Quote Originally Posted by 90 View Post
    Thankyou
    does it have an alarm/ignition cut off system anywhere?
    is the fuel pump working?
    Kalamunda, Western Australia
    I think I would definitely be looking at the fuel pump too!! If you lie down next to the tank and get someone to turn the ignition on, i am pretty sure you should be able to hear the pump start up. I had probs with my in tank pump which is why I put a commodore external fuel pump in as a back up in case the original in tank went caput.
    Hope you get it going soon.
    Shano
    Williams West Aust
    Yep,its dead.
    I will come and collect it and bury it in the local cemetry free of charge!!!!
    Im with Shano.Dead fuelpump.
    Dunydoore conversion coming up.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    mike 90 RR Guest
    Yep,its dead.
    Andrew
    and try ... Start with foot flat floor
    Test for voltage drop issues on the positive terminal post on the fire wall // Inside cabin
    The volts to the ECU plus other .... are fed from this T Post
    there must be a range rover union ! mine's gone out in sympathy. churns over, splutters a bit, dudders and dies. rev counter leaps on key turn then crashes back with a few pathetic bounces. sounds like there is an intermittent electrical zap from under bonnet when turning the key. one up so can't see it.
    fuel pump is working (took it out and it sprayed fuel), plugs get wet,unburnt fuel in exhaust. while investigating did find foot valve in vacuum adv/rtd was r/s. removing from line doesn't make it start but might be the reason for previously rich running.
    any ideas?
    mike 90 RR Guest
    Quote Originally Posted by pomonastik View Post
    any ideas?
    Ok ... ALL of the above could be solved via this link ... 6th line down is how I sorted it all out http://www.aulro.com/afvb/range-rove...nic-dizzy.html
    Same fix for 90 also
    Let us know how you went
    Mike
    ok i'm up for believing that. i've been out there with a torch, no burned wires but there is a slight stain on the plastic washer on the inner firewall, could be an indication of some corrosion beneath. i gave the underbonnet side connection a wiggle and it could be described as very slightly loose. i wasn't game to crank it over at 1am.
    i've also checked the scrap car and it's post seems bright and shiny. i'll start by stripping this one down to see how it comes apart then move on to the (supposed) 'goer'.
    i'll post back tomorrow with how it goes.
    Two Rocks, Perth
    Fuel pump seems fine.
    I checked by removing the return fuel line from the injectors, turn on the ignition and fuel pumps out of it, plenty of pressure as well (whilst trying not to inject myself).
    Tried foot to the floor for a whole battery. Tried no accelerator and tried half way.
    Same symptons as Pomonastik, wet plugs, seems like fuel. Remove the plugs and there seems to be plenty of spark, but I always have trouble with this as the earth to the block is not easy with a plug out of the motor even with two people. When the spark stops I never know whether it has died or whether the earth has gone. Jiggle it bit and it comes back, but maybe the jiggling isn't the reason. Spark from HT lead from coil to dizzy also seems OK (well there is one).
    Like the firewall terminal idea, this sounds like the sort of thing, I'll check tomorrow.
    Also like Andy's idea. If I could just find that carby fed 90 I remember I used to have, I may just tow the Range Rover into the sea. Now where did I park it, it has been a while ....
