Results 1 to 10 of 11
Thread: Defender roof rack on a Disco?
    Jul 2008
    Launceston, TAS
    Gudday.
    Will an ARB roof rack for a Defender fit onto a Disco 1 without too much mucking around? I've asked ARB about changing the mounts but they've said they only do half length roof racks for the Disco.
    Ta.
    Poida
    Nov 2006
    narellan, sydney
    No it wont.
    Sell your defender roofrack (one went for $600+ on ebay recently) and get a disco one.
    Andy
    Its the same width between the gutters, so if the ARB rack has "high" enough feet to clear the Disco roof, then yes it will fit. I have a genuine Land Rover rack on mine, the same rack fits Disco 1 and 2 and defenders as well
    Depends, if its the 1350 wide ARB then it wont fit
    But if its the 1250? one then just buy the longer legs...
    Slunnie has a full length ARB on his Disco.
    Careful, the added weight will crack the B pillar mounts.
    The legs on the defender ARB rack are too short, need to be higher to clear the high bit at the back of the disco.
    ARB sell them separtley so go and get your self a set of disco legs and fit them to your arb rack and job done .
    I will buy your Defender ones as i have an ARB on my disco and want defender legs for my defender so i can swap the rack back and forth
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Jul 2008
    Launceston, TAS
    This may be do-able... I'll look into it...
    Although, I wonder if they'll sell me 6 legs when they only do a half length rack for a disco normally. Maybe the roof isn't strong enough?
    Quote Originally Posted by Poida4x4 View Post
    They sell them in Pairs so no problem with getting 6
    And even though ARB don't make a full lenth for a disco others do so the roof can take it .
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Jul 2008
    Launceston, TAS
    $330 for a set of replacement legs!
    That plus the cost of the rack, which is a bargain from Sniegy at $250, brings some other options into play...
    Roof racks are far more expensive than I thought...
    You think that's bad.
    My wife mentioned getting a new "rack"
    Apparently this ones going to cost about $10 grand :-)
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Tombie2 View Post
    She can get a new "rack" in Thailand for less than 5k .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
