Results 1 to 10 of 36
Thread: D2 Recovery Points
    Nov 2007
    home at last - Port Macquarie NSW
    D2 Recovery Points
    anyone know a reasonable priced way of fitting recovery points to front of a D2 TD5. i have an east coast bullbar and airbags so cant mount onto bullbar.
    Rosscoe
    McDisco Guest
    Rosscoe
    There are a few options, Troutbeck Engineering make some as well as 4x4Discovery.com.au - "think outside ...".
    I have the 4x4intelligence ones. They are very well made and super strong!
    These guys are in Melbourne. Recovery Points
    Angus
    You don't want to mount onto bullbar anyway. Best thing is to get two recovery eyes, these attach off the wombat bar under the vehicle (when the tie down point is using the existing bolts on the chassis. You can then bridle two shackles for frontal recovery.
    Try www.troutbecksales.net - there a lot of others also selling these.
    Daisy Hill Queensland
    link wrong try this
    Troutbeck Sales & Services
    I haven't used them but also looking
    :TakeABow:LAND ROVER
    Don't Follow Me, I'm in a "Land Rover", You WON'T make it.
    aut viam inveniam aut faciam
    Aug 2008
    West Pennant Hills
    Rosscoe,
    I've got a single recovery point (ie on one side) which replaces the on-road recovery loop that projects through the original bumper. I initially just beefed up the original recovery loop and replaced the bolts with high tensile ones. However, when at Bruce Davis' Performance Landys, they have an example in their foyer of a recovery point which has just ripped out of the chassis. They make (and I bought) a specially designed and reinforced arrangement which strengthens the chassis at the connection point. I think it was $500, which seems a lot, but decided it was better than the cost of repair if I ripped out the connection and, worse, couldn't recover my vehicle in the bargain if I was in trouble.
    Malcolm
    Jan 2008
    Lysterfield, VIC
    Dave.
    Hi.
    96 Disco 1 V8.
    99 Disco 2 TD5.
    LROCV.
    May 2003
    On The Road
    Williams West Aust
    Hi Rosscoe
    We have a set of D2 ARB recovery points donated to AULRO by member RichardK for fundraising.I believe after seeing pics of them they fit identically to the ones I made for my D2 with ECB bullbar.You will need to buy longer high tensile bolts as they mount to chassis as the bullbar does.
    If you want to make a fair and reasonable donation to AULRO we can do a deal.
    PS I will double check my bolt spacings with Richards recovery points before closing any sale,they are made to suit ARBs D2 bullbar.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Nov 2007
    they look the go. how can i organise to get these?
    where are they at ?
    rosscoe
    I'd love a tracing of that to see if they'd fit the P38A. If they do, I'll buy a set.
    I originally was after a Yican Axle Direct Recovery system but they aren't available:
    YiCaN introduces Axle Direct Recovery. Website:www.yican.com.au
