When I first got my Series 1 it had dual Facet pumps (it has an additional fuel tank under the tub) but the high pressure was causing problems.
I ended up fitting a pressure reducer in the line set to about 3.5psi (only because the father-in-law donated it), car ran much better.
If you intend to pass through the SU pump are there valves that need removing ? I ask because I intend to hide the Facets and do much the same thing.
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
